Rear Lift I Made For My Jd 110 And 212
8 replies to this topic
#1 lyall OFFLINE
lyall
  • 2,179 Thanks
  • 1,577 posts
Posted September 04, 2013 - 03:10 PM
here are some pictures of my rear lift
made from two 2-1/2" x 1-1/2" angle, a 1-1/2" x 1-1/2 angle from the stop and 1/4" plate for the lift
no welding - just bolted it together
I also make the lift rod using 5/8" rod
grind the rod to fir the lift plate (5/16") and welded it together at both end
I also made the front lift rod  - using 3/8" rod - threaded one one  and welded the other end
all I had to buy was the two rods - both for less then $10
they work great and the depth stop does work
  • Texas Deere and Horse, KennyP, boyscout862 and 2 others have said thanks
#2 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted September 04, 2013 - 04:23 PM
Looks good. What attachment are you lifting with it?
#3 lyall OFFLINE
lyall
  • 2,179 Thanks
  • 1,577 posts
Posted September 04, 2013 - 05:13 PM
tiller or plow are used with my homemade lift
#4 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted September 04, 2013 - 05:48 PM
Nice work. :rocker2:  Any pictures on the tractor with an attachment hooked up?
  • Trav1s said thank you
#5 ckjakline OFFLINE
ckjakline
  • 1,140 Thanks
  • 1,131 posts
Posted September 04, 2013 - 05:57 PM
That looks like it'll work.Nice job. :thumbs:  :thumbs:
#6 lyall OFFLINE
lyall
  • 2,179 Thanks
  • 1,577 posts
Posted September 04, 2013 - 08:08 PM
I will put them be on my JD 112 with electric lift and get some pictures with my plow and my tiller
#7 Trav1s ONLINE
Trav1s
  • 3,521 Thanks
  • 4,498 posts
Posted September 06, 2013 - 08:06 AM
Sweet stuff!  Can't wait to see it at work.
  • lyall said thank you
#8 lyall OFFLINE
lyall
  • 2,179 Thanks
  • 1,577 posts
Posted September 06, 2013 - 02:43 PM
Rev
let know when you are coming
I might have a k301 bored .020 over - you have to see it  - new Kohler piston, rings and rod still in the box
#9 csxtrainman36 OFFLINE
csxtrainman36
  • 4 Thanks
  • 10 posts
Posted September 06, 2013 - 08:17 PM
Cool! I want one on my 317!
