Bolens 1659 ( H16Xl)
hydrolics
3 replies to this topic
#1 jesko farms OFFLINE
jesko farms
  • 1 posts
Posted September 04, 2013 - 01:29 PM
HI - We have a Bolens H16XL small garden tractor.  My brother cut the hydrolic line ( metal ) with the cable that lifts the tiller in the back.  After replacing the line ( Napa made me a rubber one ), chaning the oil filter, and replacing the oil ( 8 qrts SAE 30 - non detergent as instructed on the hood of the tractor ), the oil is "foamy" and when you stop the tractor - it spills out where the dip stick goes.  I am far from being a machanic - so any suggestions would be greatly appreciated.
#2 HDWildBill OFFLINE
  • 8,975 Thanks
Posted September 04, 2013 - 02:06 PM
Welcome to GTtalk Jesko Farms.  I know some of the Hyd systems I have worked on there is purge or bleed procedure.  The foaming is caused by air in the system.  I'm not familiar with your particular application but I'm sure someone who is will be along shortly.
  • OkieGt said thank you
#3 boyscout862 ONLINE
  • 12,552 Thanks
  • 9,046 posts
Posted September 04, 2013 - 02:25 PM
Welcome to GTT. Check out these manuals http://gardentractor...-and-operators/ , http://gardentractor...521-hydroxlpdf/ . Good Luck, Rick
The manual shows 20w oil in the transmission and hydrolic lift. You better check closely about this.
Edited by boyscout862, September 04, 2013 - 02:43 PM.
#4 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted September 04, 2013 - 03:49 PM
Hello and welcome :wave:
