Ford Lgt 145
24 replies to this topic
#16 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted September 05, 2013 - 03:19 AM
 Milkdud, your tag is on the rear fender pan straight down below the  steering column , I can see it in the picture, it is silver and most likely very hard to read if at all :thumbs:
#17 KennyP ONLINE
  • 40,173 Thanks
  • 46,783 posts
Posted September 05, 2013 - 05:04 AM
Here's a pic with measurements:
And here's the PDF for it:
Attached File  LGT 3pt Measurements.pdf   249.72KB   27 downloads
  • Russ, TomLGT195, Firemang and 1 other said thanks
#18 Rock farmer ONLINE
Rock farmer
  • 1,237 Thanks
  • 1,247 posts
Posted September 05, 2013 - 05:07 AM
Milkdud,
Welcome to the Ford / Jacobsen family!
I wouldn't get too hung up on what year it is. It was made between 1971 and 1976. They are all the same. I've seen no listing of the serial numbers by year. The best way to date it is by the engine year of manufacture. When ordering parts all you need to know is that it is a Ford/Jacobsen Open side LGT 145. Fords were also made by Gilson and others. Jacobsen also made for Oliver and Minneapolis moline.
The later models, 1977-1980, were the "closed side" and, are very similar. Some parts interchange and some don't. Those Kohler engines were used in a great meney machines. And parts a readily available. Same with the tranny and steering assembly.
Joe
  • KennyP and TomLGT195 have said thanks
#19 KennyP ONLINE
  • 40,173 Thanks
  • 46,783 posts
Posted September 05, 2013 - 06:30 AM
Anyone needing manuals, send me a PM.
Joe, thanks. Wish there was more info on these as far as year.
  • Rock farmer said thank you
#20 milkdud OFFLINE
milkdud
  • 67 Thanks
  • 68 posts
Posted September 05, 2013 - 08:34 AM
Thanks guys,
Thats actually a chalky shift knob looking like a tag in that photo.  here is another photo of the firewall.
Now that we are looking at the controls.  Question what did the red light indicate?   What was the button for, was it originally a starter button?
Thanks
Conrad
#21 Rock farmer ONLINE
Rock farmer
  • 1,237 Thanks
  • 1,247 posts
Posted September 05, 2013 - 08:59 AM
Red light indicates key on not charging. Usually engine not running. Button is not factory. That where a toggle switch went for the front electric PTO. Your tractor is key start.
Joe
  • KennyP and milkdud have said thanks
#22 nycub122 OFFLINE
nycub122
  • 25 Thanks
  • 74 posts
Posted September 06, 2013 - 05:20 AM
I would have to disagree. The red light indicates that the front PTO is engaged.
Charge/no charge is indicated by the ammeter.
I have seen the push button on several tractors, I think that a PO attempted to bypass the safety switch, so the button is used as a starter button.
Just my opinion
GEL
#23 Firemang OFFLINE
Firemang
  • 184 Thanks
  • 195 posts
Posted September 06, 2013 - 03:03 PM
Welcome to the fun.  I'm doing the same with my 145, from the pics looks like you're in the same boat I am, but these guys on here are real helpful.  The tag for the Ford serial number is down on the dash, where the rear seat/fender pan meets the column, at least it was on mine anyway.  Should be start with a "JC" and 5 or 6 digits.
#24 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted September 06, 2013 - 06:56 PM
Red light is for " pto on" indication.
#25 Rock farmer ONLINE
Rock farmer
  • 1,237 Thanks
  • 1,247 posts
Posted September 07, 2013 - 11:15 AM
Sorry. I stand corrected!
Joe
