Wisconsin Tra12D
3 replies to this topic
#1 massey 16 OFFLINE
massey 16
  • 4 Thanks
  • 38 posts
Posted September 03, 2013 - 04:37 PM
I bought an old bolens with a tra12d on it how does the ignition system work. It is a solid state. Ps tractor has sat outside for many years with no hood wiring is destroyed.
Edited by massey 16, September 03, 2013 - 04:51 PM.
#2 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted September 03, 2013 - 06:22 PM
Solid state ignition is simple: it works or it don't.  You will have one wire running to it, for a ground.  It should spark with no wires connected, and not spark if the one wire is touching the frame.
I'm assuming Bolens TRA12 works the same way.  Correct me if I'm wrong.
Ben W.
#3 boyscout862 ONLINE
  • 12,827 Thanks
  • 9,158 posts
Posted September 04, 2013 - 05:23 AM
You can download these manuals:  http://gardentractor...12d-tra-10d12d/   http://gardentractor...state-ignition/ . Good Luck, Rick
#4 massey 16 OFFLINE
massey 16
  • 4 Thanks
  • 38 posts
Posted September 04, 2013 - 04:43 PM
Is there any way to make my own ignition system.
Edited by massey 16, September 04, 2013 - 04:48 PM.
