What's It Fit?
8 replies to this topic
#1 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,034 Thanks
  • 1,457 posts
Posted September 02, 2013 - 08:21 PM
   I picked up a Craftsmen snowblower at an auction awhile back. Didn't have anything it would fit on,but it went cheap!!! I was wondering if anybody knew what it fit. It is a model 842-210722. I'll get pics. of it tomorrow.
#2 MH81 ONLINE
  • 29,211 Thanks
  • 29,417 posts
Posted September 02, 2013 - 08:26 PM
Pics would be a big help. I believe the mfg is Haban, but beyond that... What mount, belt orientation, etc?
I will take the number and look.
  • LTD said thank you
#3 MH81 ONLINE
  • 29,211 Thanks
  • 29,417 posts
Posted September 02, 2013 - 08:28 PM
Number isn't anything recognized by Sears US. It is possible it's a Canadian model derivation.
#4 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,034 Thanks
  • 1,457 posts
Posted September 02, 2013 - 08:33 PM
It is for a vertical shaft tractor. Tag says Sears and Roebuck so it is an older one.
#5 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,034 Thanks
  • 1,457 posts
Posted September 02, 2013 - 08:36 PM
Yea, I did a search but didn't find a whole lot. Actually Google had NOTHING for the full model number.
#6 MH81 ONLINE
  • 29,211 Thanks
  • 29,417 posts
Posted September 02, 2013 - 08:48 PM
Not seeing anything on sears, Canada or US. Huh, doubt it's a model for Mexico... :wallbanging:
#7 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted September 02, 2013 - 09:59 PM
Possibly for a GT18V, was made by Haban, Sears has dozens of these 842 blowers on their site, but none with as many numbers after the 842 as the one you posted
#8 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,034 Thanks
  • 1,457 posts
Posted September 03, 2013 - 07:46 AM
Here are some pics. I read the number wrong though. It is 842-2-0722. Least that's what it look like.
Edited by LTD, September 03, 2013 - 07:49 AM.
#9 TAHOE ONLINE
TAHOE
  • 7,313 Thanks
  • 5,356 posts
Posted September 03, 2013 - 09:01 AM
I've got a 842.240510 so not sure how close in years it is to yours, but the looks are the same.
Got mine mounted on a mid 90's Craftsman "Gold" basically an LT1000, mounted on a late 80's craftsman before that. I would say if you can't find your model #, use mine for parts as they looks identical. I can show you pics off all the mounts also, has a set bolted to frame behind front tires and another set bolts to frame right in front of rear tires.
Looks like someone has changed the engagement lever on your idler puller, don't think the red ball was a stock item . :D
Kinda hard to explain, but mine had a tube the slides over the lift arm that turns. The rod was attached to it, you turned the tube to engage pulley.
EDIT: looking at your pictures, that is 240722, not a 1 or a dash. Stamped probably 3rd shift on Saturday morning at 6:30 right before quitting time :D
Edited by TAHOE, September 03, 2013 - 09:04 AM.
  • MH81 and LTD have said thanks
