Got A Few New To Me Inplements!
7 replies to this topic
#1 dropped82 ONLINE
dropped82
    Nut Case
  • 2,493 Thanks
  • 1,816 posts
Posted September 01, 2013 - 11:44 PM
I got these a few weeks ago. Gentleman had them about 20 minutes from me. A Brinly plow, cultivator, sears disc, and back blade. They all had been worked on to fit his JD 445 3 point. Fortunately he only welded a top link bar and left the sleeve yoke intact. Easy fix there. As for the disc and back blade, I'm wanting to convert and add a sleeve yoke. I also have a 46" blade in the shed to replace that small blade currently on it. Couple holes drilled and a yoke welded on and I have a nice back blade. As for the discs, anyone think a sleeve hitch could lift doubles? I have another set of Sears discs I'm wanting to attach. I figured with the Sears being a little smaller it may work. Any thoughts? Anyone tried this setup?
Thanks
Eric
Sent from my SPH-D700 using Tapatalk 2
  • sacsr, boyscout862 and JRJ have said thanks
#2 KennyP OFFLINE
  • 38,196 Thanks
  • 45,842 posts
Posted September 02, 2013 - 06:13 AM
Nice set of implements! Forgive me, but which tractor w/sleeve hitch are you wanting to use these on? I would think a tandem disk might be a bit much for a sleeve hitch as you would have a lot of weight hanging off it way back there. I have that back blade in the sleeve hitch version. It's a heavy sucker.
  • dropped82 said thank you
#3 CRFarnsworth OFFLINE
CRFarnsworth
  • 4,664 Thanks
  • 2,140 posts
Posted September 02, 2013 - 08:01 AM
Lucky you!  :thumbs:   Rick
#4 dropped82 ONLINE
dropped82
    Nut Case
  • 2,493 Thanks
  • 1,816 posts
Posted September 02, 2013 - 08:45 AM
They would be on the back of my 442. I have some front weight for it to help keep the front down. I don't think the hydraulics will have a problem lifting them.
Eric
#5 shorty ONLINE
shorty
  • 5,456 Thanks
  • 5,256 posts
Posted September 02, 2013 - 05:05 PM
Nice set of implements. They will be fun to use!
#6 TAHOE ONLINE
TAHOE
  • 7,946 Thanks
  • 5,666 posts
Posted September 03, 2013 - 09:08 AM
Man, I am sooo wanting a Sears back blade. You lucky dog, nice set of implements.
  • KennyP and dropped82 have said thanks
#7 freedhardwoods OFFLINE
freedhardwoods
  • 374 Thanks
  • 197 posts
Posted October 01, 2013 - 04:34 PM
That is a great haul. All in one place and that close is a big plus.
If it helps any, this disc on my 446 with weight added to make it about 350 lbs total was a strain to pick up.
#8 OldBuzzard OFFLINE
OldBuzzard
  • 7,018 Thanks
  • 4,790 posts
Posted October 01, 2013 - 06:04 PM
With a hydraulic lift, and depending on what tractor you have, you might be able to lift a tandem disk setup.  I danged sure wouldn't want to try lifting them with the 'armstrong" lift  :D :D :D
However, the Brinly manual says NOT to do it.  They say that are not designed to be lifted.
Edited by OldBuzzard, October 01, 2013 - 06:05 PM.
