* * * * * 1 votes
John Deere 140 Make Over
60 replies to this topic
#31 BTS ONLINE
BTS
    Make Stuff Up
  • 4,267 Thanks
  • 2,461 posts
Posted September 13, 2013 - 08:30 PM
Hopefully the engine I have will fit right in.
Thanks for the specs, pictures and info.
I haven't ground down the teeth yet, I'm going to grind the sides down so it will run a little smoother.
Thanks again for the info
I'll get some updated pictures up in a little while
Edited by BTS, September 13, 2013 - 08:32 PM.
#32 BTS ONLINE
BTS
    Make Stuff Up
  • 4,267 Thanks
  • 2,461 posts
Posted September 13, 2013 - 08:41 PM
Got both sprockets finished, I still need to grind down one but I ran out of grinder wheel on my angle grinder.
The one sprocket looks like it's going to work pretty good, I laid out the chain and sprockets to get a idea on what it's going to look like. I'm going to start on the sub frame Saturday, Hopefully I can get it finished Saturday evening and then see what it all looks like.
It's coming together faster then what I thought it would, I thought the sprockets would take a lot longer then what they did.
Thanks
#33 michael.kitko ONLINE
michael.kitko
  • 505 Thanks
  • 462 posts
Posted September 14, 2013 - 05:21 AM
This is looking good, I really can't wait to see it finished...
  • BTS said thank you
#34 BTS ONLINE
BTS
    Make Stuff Up
  • 4,267 Thanks
  • 2,461 posts
Posted September 14, 2013 - 08:02 PM
Thanks
I got the second sprocket finished, it looks like it's going to work pretty good :dancingbanana:
I started digging around in the shed and I found two old top link type of a deals? I think they go on a old disk / plow or something.
They have a forked end that the small sprockets fit right into, I cut these up and I'm going to use them for the track adjustments.
As you can see in the picture, the threaded end will slide into a pipe and then I can move the nut either way to change the length.
(I hope all of this makes since) :say_what:
I was going to start on the frame today, but I found the adjusters, got excited and I started working on them instead :D.
I'm not going to have much time to work on this Sunday, but maybe I can get a little further along on Monday.
Thanks :firejumper:
#35 BTS ONLINE
BTS
    Make Stuff Up
  • 4,267 Thanks
  • 2,461 posts
Posted September 15, 2013 - 06:52 PM
I'm wondering If I need to ad a big ish spring on each track adjuster so it will have a little "give" for when I hit stuff with it?
What are your thoughts? do you think it would be fine with out it?
Thanks for any impute :poke:
#36 olcowhand ONLINE
  • 41,255 Thanks
  • 31,447 posts
Posted September 15, 2013 - 07:01 PM
Depends on how you plan to use it.  If you plan to work it any, then yes, you need the spring cushion.  If a rock or something got under a track chain, something may break without the spring.
  • KennyP and BTS have said thanks
#37 BTS ONLINE
BTS
    Make Stuff Up
  • 4,267 Thanks
  • 2,461 posts
Posted September 15, 2013 - 09:51 PM
That's what I was thinking, I would hate for something to get caught and break a track :wallbanging:
I am planing on using the tar out of this lol :thumbs:
I'm out fitting it with a push blade, loader, ripper (on the rear) and a backhoe! :dancingbanana:  And probably more once I think of more attachments :D
Can't wait to get it finished :firejumper:
  • KennyP and twostep have said thanks
#38 BTS ONLINE
BTS
    Make Stuff Up
  • 4,267 Thanks
  • 2,461 posts
Posted September 15, 2013 - 10:33 PM
Found springs to use, I have some old motorcycle rear springs that are the right size! :rocker2:
That's why I never through stuff away, it always comes in handy one day! lol  :smilewink:
#39 BTS ONLINE
BTS
    Make Stuff Up
  • 4,267 Thanks
  • 2,461 posts
Posted September 16, 2013 - 07:06 PM
Started on the frame, got a fair amount done today.
I'm using frame off of a Allis Chalmers WD, I have a small tractor salvage business so I have a lot of frame laying around.
It's looking pretty good so far, I think it's going to work pretty good.
But I think it's stout enough :D
WHEN WAS THE LAST TIME I OVER DID ANYTHING :bigrofl:
  • twostep said thank you
#40 BTS ONLINE
BTS
    Make Stuff Up
  • 4,267 Thanks
  • 2,461 posts
Posted September 17, 2013 - 07:18 PM
Got some more welding done on the frame today, I set the 140 on for a test fit and it looks like it's going to work pretty well :dancingbanana:
I also got the forks for the front sprockets finished, but I didn't get pictures :(
So far this is coming along pretty well, I'm hoping to start building the tracks in a few days :thumbs:
Edited by BTS, September 17, 2013 - 10:17 PM.
#41 BTS ONLINE
BTS
    Make Stuff Up
  • 4,267 Thanks
  • 2,461 posts
Posted September 18, 2013 - 07:51 PM
Didn't have much time to work on it today,
I did get the front sprockets mounted, now I need to ad the springs onto them and they should be ready to go :dancingbanana:
I'm hoping to get the rear sprockets finished tomorrow.
I'm not sure what this sub frame weighs, but it has to be over 200lbs, it's all I can do to stand it up and slide it onto the bench
        :anvil_drop:
I was planing on adding weights on the sub frame for better stability, but I don't think that's going to be a issue now! :D
If all goes as planed (and it usually doesn't) I should be sizing the chain for tracks and welding the cleats on!!! :biting_nails:
#42 BTS ONLINE
BTS
    Make Stuff Up
  • 4,267 Thanks
  • 2,461 posts
Posted September 19, 2013 - 10:40 PM
Didn't have time to work on it today :ah_shoot:
But it's now raining, so I should have a full day tomorrow to work on it :thumbs:
(you can read on why I didn't have time here http://gardentractor...g-haul-combine/)
#43 BTS ONLINE
BTS
    Make Stuff Up
  • 4,267 Thanks
  • 2,461 posts
Posted September 20, 2013 - 08:45 PM
Got the rear sprockets done up today, I am hoping to size up the chain and start on the tracks tomorrow (saturday)
  • Cat385B said thank you
#44 BTS ONLINE
BTS
    Make Stuff Up
  • 4,267 Thanks
  • 2,461 posts
Posted September 21, 2013 - 07:57 PM
Got the loader mounts welded on just to find out they are in the way of the tracks :(
I guess I'm going to make the loader mounts into track runners to help keep the tracks from sagging on top :thumbs:
Got all 4 forks and sprockets finished and mounted.
It seems like I got a lot of welding done so maybe it will start coming together a little quicker.
I don't like how the rear sprockets stick out so far, I think I'm going to move them in closer, I wasn't planing on having them out so far, but I guess I got a measurement off.
  • olcowhand said thank you
#45 twostep OFFLINE
twostep
    Rockstar
  • 1,987 Thanks
  • 2,538 posts
Posted September 21, 2013 - 09:45 PM
You've done a lot of work on this thing! That chassis looks beef.
It looks like you track will be quite a bit longer than most. Don't forget that the longer/more ground contact you have the harder it is going to be to turn.
  • BTS and Chopperhed have said thanks
