Which Type Of Garage Lighting Is Best?
30 replies to this topic
  • 2,331 Thanks
  • 1,498 posts
Posted September 01, 2013 - 06:20 PM
I am rebuilding my garage and that gives me an opportunity to install new & better lighting. What type of lighting would you pick: standard screw-in light bulbs, normal 4 foot florescent lights, 4 foot LED tubes, standard base LED bulbs, standard base CFL's, mix-n-match, etc?
Factors to consider:
   1)  I live in Canada & we get below zero temperatures, so cold starting is important.
   2)  The more power dedicated to lighting, the less I have for the toys like my welder.
   3)  Adjustable height would be nice.
   4)  The budget is not meager, but there are limits.
#2 DH1 ONLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,566 posts
Posted September 01, 2013 - 06:58 PM
Compact florescent that screw into standard light bulb sockets.
Compared to incandescent bulb they burn less hydro.
Compared to standard florescent tubes they start when cold, not full brightness but after 5 minutes they are.
  • boyscout862 and New.Canadian.DB.Owner have said thanks
#3 shorty ONLINE
shorty
  • 5,468 Thanks
  • 5,257 posts
Posted September 01, 2013 - 07:03 PM
I use the standard screw in bulbs. But that just gives spot lighting effect. My favorite is the halogen lights.
Best part that I like about halogen in winter, is it gives one little heat spot to warm my fingers in the unheated shed.
  • sacsr, boyscout862 and New.Canadian.DB.Owner have said thanks
#4 MH81 OFFLINE
Posted September 01, 2013 - 07:08 PM
I would go with a mix n match. In my little shed, I have 2 of the newer style fluorescents that (almost) always start... I also have 2 old fashioned lights, one being my trouble light on the same switch. In the winter, I leave these on too so I can see if I just have to step In and grab something or if I have to wait for the fluorescents to come on I can still do a few things.
  • GTTinkerer, sacsr, HDWildBill and 1 other said thanks
#5 gopher OFFLINE
gopher
  • 761 Thanks
  • 756 posts
Posted September 01, 2013 - 07:23 PM
The led is by far the least energy consumer of them all . If below 10 below compact fluorescent sometime does not work. Go to building supplier store they usually have lighting displays close enough to compare you can decide what one will give you the kind of light your wanting. But the led cost  about 1/2  what compact flur. to operate.
  • sacsr, boyscout862, New.Canadian.DB.Owner and 2 others have said thanks
#6 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted September 01, 2013 - 08:37 PM
Old school 4' fluorescent for me,( just get the units for cold area's, they start right up in cold weather).
LED's are great energy savers, but until the cost comes down a lot I think you could spend a grand real easy for a bright area.
But, I would also look into some LED task lighting, I use them for service work, 12v units that we charge in our trucks between calls, they work great, very bright, long lasting too. We also have 120v LED lights for jobs that are longer than a hour, both drop lights and flood, just remember you get what you pay for, when it comes to LED's cheap = blue-weak, and 100 bucks gets you white & bright. :thumbs:
  • DougT, sacsr, HDWildBill and 3 others have said thanks
#7 boyscout862 OFFLINE
  • 12,831 Thanks
  • 9,158 posts
Posted September 10, 2013 - 06:58 AM
Add a woodstove to keep you and the lights warmer. I like four foot flourescents but they don't seem to last very long any more. If you just put a duplex outlet where you want lights, you can then play with it as you like. Good Luck, Rick
Edited by boyscout862, September 10, 2013 - 06:59 AM.
  • HDWildBill and New.Canadian.DB.Owner have said thanks
#8 TerryD OFFLINE
TerryD
  • 132 Thanks
  • 254 posts
Posted September 10, 2013 - 07:20 AM
I put halogen floods in the corners of my garage and compact fluorescents suspended from the ceiling with old school barn lamp shade reflectors. The halogens are on separate switches so I can turn them on for extra light when doing detail work.
#9 HDWildBill OFFLINE
  • 8,975 Thanks
Posted September 10, 2013 - 09:26 AM
I have the 4' double row compact Florence lights in the shop and I have been pretty happy with them.  But that been said I don't get the cold temps you do so I really don't know how they would be up there.  When I wired up my shop I did do like Rick suggested and used duplex outlet's and plug the lights into them.  I figured if I had to change out one of those monsters it would be a whole lot easier to just unplug it and remove a couple of screw then to have to worry about rewiring it.
#10 TomLGT195 OFFLINE
TomLGT195
  • 3,823 Thanks
  • 2,811 posts
Posted September 10, 2013 - 06:33 PM
8' tube fluorescents work good for general purpose usually last pretty good and for a little more they come with a cold start ballast, you may have to check with local electrical supplier for those.
I too use the duplex outlet method. I have several located around the room for possible movement or additions of lights.I use a different color outlet plate so I know which ones are on the switch. remember don't put too many outlets on one circuit, ( follow code for your area, check with local building inspector), but you will only draw on how many lights you have plugged in and have the ability to move or add lights as needed. my garage has 5 lights (3- 8' and 2 -4' with pull switches over dedicated areas ) on a single 15 amp circuit
note the reflective foil faced insulation to help with heat and light reflection
i also have portable stand halogens for a extra boost of light when needed, and a little heat too.
#11 IamSherwood OFFLINE
  • 8,391 Thanks
Posted September 10, 2013 - 07:01 PM
T8 fluorescent 4ft work good. The have electronic ballasts, so you don't get that
annoying flicker/flutter that you get from the older/larger T12 bulbs. I've never
had a problem with cold start up, and haven't changed a bulb in 8 years, since new.
  • GTTinkerer, New.Canadian.DB.Owner and TomLGT195 have said thanks
#12 NJKen OFFLINE
NJKen
  • 1,361 Thanks
  • 1,284 posts
Posted September 10, 2013 - 07:33 PM
Yep great suggestion.
Most T-8 fixtures have "0 degree" starting ballasts. Can go to T-8 HO for below 0
I went with T-5 HO fixtures in my garage/shop. And LOTs of them. Can't ever have too much light IMO.
I have 4 rows of 8' 4 lamp fixtures. But each row is on its own switch. One or two rows on is great general light. All four on I can do surgery.
  • New.Canadian.DB.Owner and WNYTractorTinkerer have said thanks
#13 HydroHarold OFFLINE
HydroHarold
  • 703 Thanks
  • 977 posts
Posted September 10, 2013 - 09:19 PM
So that's the glow I see in the sky Southwest of here!  You must have the doors open!:D
I had 4 T8's put in a couple years ago and they work very well.  It still takes 'em a short time to warm up in the cold, but no flicker.  With the wattage I had left over I removed the tungsten 150's from the 2 regular sockets left and put in 45w. CFL spirals.  They take a while to light but fill nicely.
#14 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,802 posts
Posted September 11, 2013 - 11:21 AM
Now you've got me thinking...  an OR light would be great in the shop.... hmmmm.
#15 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,451 Thanks
  • 5,762 posts
Posted September 11, 2013 - 12:38 PM
You better not leave them on or HH may show up @ your shop!!
4 4' T8's on the roof and some old juice-hog 8' 300 watters over the workbenches for thes old eyes to see something..
And HH-  I keep the doors closed!!  :D
