Need help finding lift bracket for my Cub Cadet 147.
13 replies to this topic
#1 NUTNDUN OFFLINE
  • 10,353 Thanks
Posted November 28, 2010 - 03:31 PM
I had finally bought a snow plow for my Cub Cadet 147 but I am missing the one bracket that is at the lift. I had seen the bracket that I need on another tractor at a show once. I think it is an s shaped bracket. I tried finding it on the parts search on Cub Cadet's website but the only thing that I could find was part number 489622-R1 but I am almost positive that is not the piece I need.
I was trying to dig through pictures to see if I had a pic of a tractor with one but I can't find one. I would really like to get the bracket so I can mount my snow blade on the 147. I know the piece I need is the one they make mention of in the service manual about having to cut down to fit with the electric lift.
#2 M&M13 OFFLINE
M&M13
  • 11 Thanks
  • 159 posts
Posted November 28, 2010 - 04:33 PM
Hey nutndun, dont know if these pics will help or not some people call a blade a plow so best i can do !:wave:
#3 mjodrey OFFLINE
Posted November 28, 2010 - 04:44 PM
I wish I could help you George,but I can't seem to find anything on that.
#4 M&M13 OFFLINE
M&M13
  • 11 Thanks
  • 159 posts
Posted November 28, 2010 - 05:13 PM
#5 NUTNDUN OFFLINE
  • 10,353 Thanks
Posted November 28, 2010 - 05:45 PM
It's not on the snow blade or snow blower although I would need it for either attachment. The side shot you have of the tractor, it is at the bottom of the lift handle. I can't see it very good to highlight it. Need a bigger shot of the side of the lift handle at the bottom.
#6 DMF OFFLINE
DMF
  • 10 Thanks
  • 285 posts
Posted November 29, 2010 - 01:58 PM
George - Call this guy: Michael Miner 860-309-0875.
He has a ton of plows for CC's as well as anything else you'd want; he can help you out.
Rich
#7 Grumpy OFFLINE
Grumpy
  • 748 Thanks
  • 624 posts
Posted November 29, 2010 - 03:24 PM
There were two on ebay about 3 weeks ago. Igot one of them. I don't look at ebay unless I need something so I don't know if ther is one now. Look here . http://www.cubclassi...m/cubparts.html
$15.00
Edited by Grumpy, November 29, 2010 - 03:36 PM.
#8 NUTNDUN OFFLINE
  • 10,353 Thanks
Posted November 29, 2010 - 05:43 PM
There were two on ebay about 3 weeks ago. Igot one of them. I don't look at ebay unless I need something so I don't know if ther is one now. Look here . Cub Cadet Classics
$15.00
Thanks Grumpy, but I don't think that is the piece that I need but I could be completely wrong. Is that the piece that they show in the manual that needs cut down to work with an electric lift?
#9 NUTNDUN OFFLINE
  • 10,353 Thanks
Posted November 29, 2010 - 05:44 PM
Rich
Thanks Rich. I will try giving Michael a call tomorrow.
#10 NUTNDUN OFFLINE
  • 10,353 Thanks
Posted November 29, 2010 - 05:54 PM
$15.00
I guess that is the piece I need Grumpy. I just pulled up the manual again and that is the one they show needing cut down to work with the electric lift. I will keep my eye out for one.
Now does anyone have a good picture of that piece mounted? :D
#11 DGS345 OFFLINE
DGS345
  • 17 Thanks
  • 348 posts
Posted November 29, 2010 - 05:59 PM
if you cannot find one and get me some good measurements and a print I could make you one
#12 Grumpy OFFLINE
Grumpy
  • 748 Thanks
  • 624 posts
Posted November 29, 2010 - 06:34 PM
Click on this link Cub Cadet Classics They have them in stock. Look under used parts.
#13 M&M13 OFFLINE
M&M13
  • 11 Thanks
  • 159 posts
Posted November 29, 2010 - 07:40 PM
CUB CADET NARROW FRAME LIFT ARM BRACKET 489 622 R1 - $25.00 :: Patton Acres - Cub Cadet Garden Tractor Parts new and used
#14 NUTNDUN OFFLINE
  • 10,353 Thanks
Posted December 25, 2010 - 09:21 PM
Well I never did buy the lift arm bracket and had time this weekend working in the garage putting wheel weights on the Cub and figured I might as well make the bracket. It may not be perfect but it gets the job done. :D
I just took a piece of 1 1/2" wide 1/8th thick piece of flat stock and cut it to length and drilled the mounting holes and I also added the clamp but I don't think it is really needed. It will work for now till I order the proper piece. I would have liked to of used a piece of 1/4" flat stock but they didn't have any at the local Ace hardware.
