Looks Like Rebuild Time For K301
5 replies to this topic
#1 Jkrogers OFFLINE
Jkrogers
  • 9 Thanks
  • 70 posts
Posted September 01, 2013 - 05:19 PM
I have been working on a 129 restore. Fired it up yesterday, it smoked really bad and after a bit oil started coming out of the exhaust. How far should I go on the rebuild? Advice on rebuilding is appreciated. I only want to take it apart once. Thanks!
  • Dieselcubmike said thank you
#2 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted September 01, 2013 - 05:47 PM
If you are going to do a rebuild, it is worth doing it completely. You will have an engine to last a lifetime!
Geno
  • Jkrogers said thank you
#3 ckjakline ONLINE
ckjakline
  • 1,140 Thanks
  • 1,131 posts
Posted September 01, 2013 - 07:30 PM
I would buy a rebuild kit.I think there around $150.I think the kits include connecting rod,valves,piston,rings, bearings,and gaskets.
#4 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,348 Thanks
  • 9,802 posts
Posted September 01, 2013 - 07:31 PM
You will need to take it apart completely and measure the cylinder and rod journals to see what it needs. If you aren't competent to do this, the machine shop will. If everything measures good, you may only need rings and a valve job. But, most likely, you will need more. Remember to 86 the balance gears. . . . .  or make some really nice candle holders for Christmas, your choice. It's always good to install new governor gears and point pushrod at rebuild.
#5 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted September 01, 2013 - 08:58 PM
If you are going to do it, do it all the way.  Spend the extra money to guarantee you won't ever have to do it again.  Your grandkids might, but if it is done well it will last you.
A good rebuild is costly, but they don't make K series engines anymore, although they should: they were the best for the time.
Ben W.
  • Jkrogers and Rock farmer have said thanks
#6 Jkrogers OFFLINE
Jkrogers
  • 9 Thanks
  • 70 posts
Posted September 02, 2013 - 11:33 AM
Thanks guys, this tractor was close to being a parts tractor when I got it and it has taken awhile to gather parts to get it cranked to see what I had. I have got a good machine shop guy and I will get it torn down and work to get it back together right. Good thing is the hydro seems to work just fine.
I have a lot of experience with engines but not a lot with small engines. Sometimes they can be more be challenging than a full size engine.
