Does The Output Shaft Of The 8Hp Kohler In My 72 John Deere Turn Counter Clockwise?
6 replies to this topic
#1 Betty Humpter OFFLINE
Betty Humpter
  • 13 Thanks
  • 29 posts
Posted August 30, 2013 - 08:19 PM
the starter is gone on the engine so I cannot tell which way it turns, and what is the diameter of the shaft?
Edited by Betty Humpter, August 30, 2013 - 08:24 PM.
  • JRJ said thank you
#2 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted August 30, 2013 - 08:25 PM
I believe you are correct. The flywheel should turn counterclockwise.
  • Betty Humpter said thank you
#3 Guest_gravely-power_*
  • Guests
Posted August 30, 2013 - 08:53 PM
Yup. CC
#4 JDBrian OFFLINE
  • 9,601 Thanks
Posted August 31, 2013 - 06:47 AM
Crankshaft clockwise, flywheel CCW.  So it depends what you mean by "shaft".
#5 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,748 Thanks
  • 4,242 posts
Posted August 31, 2013 - 06:59 AM
here you'll find the PM TP-2137-A of the KOHLER K181 - w/out the diameter - and here a Service Manual, maybe it will help you.
Edited by jd.rasentrac, August 31, 2013 - 07:28 AM.
#6 Guest_gravely-power_*
  • Guests
Posted August 31, 2013 - 07:07 AM
Fly wheels turn clock wise.
#7 Betty Humpter OFFLINE
Betty Humpter
  • 13 Thanks
  • 29 posts
Posted August 31, 2013 - 08:12 AM
do the pullys turn clockwise or counterclockwise?
