Live Action In Nj
6 replies to this topic
#1 NJKen OFFLINE
NJKen
  • 1,361 Thanks
  • 1,284 posts
Posted August 29, 2013 - 09:43 PM
No I'm not chasing wild animals around.
I'm TRYING to get 2 wheels & tires off of a scrap axel.
Nothing is working sadly.
I sprayed it and let it soak with every brand penetrating oil on my self. Then I beat the snot out of it with a 3 lb maul. Not budging.
Tried this tonight. Portable fork lift with 2000 lbs of lift capacity. Nothing.
I'm letting it soak overnight under pressure, maybe that will work
If not, I'll hit it with the torch and try heat the next time I have time to play with it. ImageUploadedByTapatalk1377830524.667497.jpg ImageUploadedByTapatalk1377830537.843996.jpg
I've never seen them stick this bad. But I guess it happens.
Any tips ? Please chime in.
Thanks
  • OkieGt said thank you
#2 shorty ONLINE
shorty
  • 5,468 Thanks
  • 5,258 posts
Posted August 29, 2013 - 09:58 PM
Uh, get a buddy with a bigger lift. :D  :D
#3 marlboro180 OFFLINE
marlboro180
  • 635 Thanks
  • 954 posts
Posted August 29, 2013 - 11:00 PM
Please, please do not use the torch.... Don't wanna hear about you going through a wall....BTW, I have been driving one of my splined axled riders around w/o the axle clips for months and weekly treatments of Pipe Break, to no avail.... Good luck bub!
#4 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted August 29, 2013 - 11:01 PM
If not, I'll hit it with the torch and try heat the next time I have time to play with it. attachicon.gifImageUploadedByTapatalk1377830524.667497.jpgattachicon.gifImageUploadedByTapatalk1377830537.843996.jpg
Thanks
Portable hydraulic ram?
#5 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted August 30, 2013 - 05:10 AM
Heat gets my vote but remove the pressure from the lift first. Try torque, if you can, rather than pulling. If you can get the wheel to turn even slightly it might break the bond.
#6 MH81 OFFLINE
Posted August 30, 2013 - 07:31 AM
I had an axel I was trying to save the wheels off of. Same thing.
I managed to save 1 of them only, by driving it further on (3/32) then ground the end of the shaft clean and worked it on & off until free.
Tried on the other side and never did get it, even with blue wrench involved.
#7 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,451 Thanks
  • 5,763 posts
Posted August 30, 2013 - 08:03 AM
Torch was the only thing that let me get the severely rusted axle to rim connections apart on my old cub..  I gave it heat and then a good whack with the sledge and an old hunk of iron piping to loosen things up and it came apart begrudgingly..  Those things are a PITA for sure..  If you use heat don't use the lift as you will toast the rim for sure..  Work directly on the stuck connection or things will bend/distort..  I pulled it off the rest of the way with a puller and a couple bolts and it was a Biotch to get it off- period!  Gobs of never-seize were liberally applied before reassembly!
