Inner Tube Oil
30 replies to this topic
#1 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted August 29, 2013 - 08:45 PM
I was ordering inner tubes the other day, and got to talking to one of the mechanics about how to preserve these tubes. He said they soak the inner tubes for a day in a big container of peanut oil before inserting them into the tires. The valve stem cores are removed, so that the oil can get inside and coat the inside walls. He said the oil keeps them from dry rotting in the tire and helps to keep them from splitting from the heat. I asked if used motor oil can be used as an alternative, but he said the motor oil has a tendency to be too thick, so they use the peanut oil as it is much thinner, and coats more easily.
Has anybody else ever heard of this, or better yet, has tried this? I'm curious to hear the results if this method was used or if it actually works. I know for a fact that tubes dry out after a couple of years, and some split from constant air pressure changes, so if this works, and it means getting a few more years out them,  I'm willing to give it a try.
  • lyall, larryd, JRJ and 3 others have said thanks
#2 DH1 ONLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted August 29, 2013 - 08:50 PM
I always thought that motor oil and rubber don't mix, the oil deteriorates the rubber.
ATF would be better I think. ???
Don't know about Peanut oil, never heard of it before.
Edited by DH1, August 29, 2013 - 08:53 PM.
  • olcowhand, johndeereelfman, larryd and 1 other said thanks
#3 Texas Deere and Horse ONLINE
  • 14,815 Thanks
  • 15,502 posts
Posted August 29, 2013 - 08:52 PM
Never heard of it, but waiting to see who everyone else answers.
  • johndeereelfman and larryd have said thanks
#4 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted August 29, 2013 - 08:57 PM
Doug,
I thought the same too, and when I brought that up to the mechanic, he simply asked me if I had even see rubber valve cover, or oil pan gaskets? His point was then taken.
  • larryd said thank you
#5 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted August 29, 2013 - 09:26 PM
Doug,
Troy, I knew a guy who would dunk a tube in oil before trying to install it.  It would slip right in.  I never tried it just because of the same concern you had.  I wonder who's right?
Ben W.
#6 AVB OFFLINE
AVB
  • 138 Thanks
  • 135 posts
Posted August 29, 2013 - 09:56 PM
I have no idea about the oil, but I do use either corn starch or bably powder as lube when replacing tubes in motorcycle tires.
  • johndeereelfman, HDWildBill and larryd have said thanks
#7 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,064 posts
Posted August 29, 2013 - 10:17 PM
I have never heard of that. My Dad uses Peanut oil for cooking everything, I might have a hard time trying to use a bottle of his :D
All the valve cover and oil pan gaskets I get are rubber, so not sure why he said that either??. You should have countered him by saying "then why is there a rubber gasket on an oil filter?" :rolling:
There are also many types of rubbers today. The type a tube is made out of, I would think engine oil would deteriorate?
I just hope he's not pulling your leg? like when I was an Auto Mechanic and I would ask people if they rotate there spark plugs every 5k miles. ( as a joke) :D
#8 Arti OFFLINE
Arti
  • 1,363 Thanks
  • 989 posts
Posted August 30, 2013 - 05:35 AM
Neoprene is a closed cell rubber that resists oil.
The downside of peanut oil I suspect would be that it would attract rodents that would likely chew on the valve stems.
Sunlight is one of the enemies of rubber so I would cover the tires or store them tires inside.
#9 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted August 30, 2013 - 08:34 AM
Well Chris, I think you have a source! Strain any partical out and use his used oil he is going to throw out. Ultimate Recycling.
#10 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted August 30, 2013 - 10:13 AM
If the peanut oil gets inside the tube how do you get it all out?
Dick
#11 olcowhand ONLINE
  • 41,274 Thanks
  • 31,449 posts
Posted August 30, 2013 - 11:16 AM
Definitely DO NOT use ATF!!!!!!!  One of my John Deere F935's had a slight axle leak, and it would run down the rim onto the valve stem.  The stem swelled up huge & softened to the point the rubber shed itself from the steel of the valve core......flat tire!    I would never use any petroleum product on a tube.
#12 Guest_gravely-power_*
  • Guests
Posted August 30, 2013 - 11:24 AM
I would think you wouldn't want to put any liquid in a tube/tire if it goes faster than a GT. Talk about an unbalanced condition after it has set and pooled over night.
#13 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted August 30, 2013 - 05:04 PM
Any petro based oil will eat at the rubber, our tire shop uses vegetable oil to mount tires. It actually called tire soap but there's no soap in it.  I believe that what the dealer makers also recommend.
  • Alc, johndeereelfman and larryd have said thanks
#14 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,803 posts
Posted August 30, 2013 - 05:34 PM
Just to reiterate, the rubber used in tires is not compatible with oil (ATF is oil, just with different additives.)  The type of rubber used in gaskets is different than tires.
#15 AVB OFFLINE
AVB
  • 138 Thanks
  • 135 posts
Posted August 30, 2013 - 06:18 PM
I use Ruglyde, I think its about the same thing as Murphy's oil soap like you use on hardwood floors.
