What Engine Is This?
9 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted August 29, 2013 - 05:16 PM
No numbers that I can find. What engine do you think this is? The starter in out and I need to find one.
It's a statesman mower
Sent from my SCH-I535 using Tapatalk 2
#2 Utah Smitty OFFLINE
Utah Smitty
  • 1,698 Thanks
  • 1,781 posts
Posted August 29, 2013 - 06:14 PM
offhand, I'd say a Tecumseh...they stamp the model # in the fan shroud. post some more pics of the sides, carb, etc. for better chance to id.
#3 Arti OFFLINE
Arti
  • 1,362 Thanks
  • 988 posts
Posted August 29, 2013 - 06:49 PM
Those were usually a Briggs engine, Sears sold them and I believe that MTD was the manufacturer
#4 Bolens 1000 ONLINE
  • 14,612 Thanks
  • 17,951 posts
Posted August 29, 2013 - 06:52 PM
:ditto:
The Shroud and Oil Dipstick look Briggs to me
#5 AcreFarm OFFLINE
AcreFarm
  • 110 Thanks
  • 359 posts
Posted August 29, 2013 - 06:53 PM
That's either a 25xxxx or a 28xxxx Briggs.   The air filter housing is from a smaller model Briggs.  The model, type & code should be stamped in the shroud, just above the sparkplug.
#6 EricFromPa ONLINE
EricFromPa
  • 3,224 Thanks
  • 2,907 posts
Posted August 29, 2013 - 07:53 PM
Looks like a 12hp Briggs and Stratton.
Model numbers should be stamped on the front of the Blower housing like this.
Looks like an older Steel ring gear flywheel.Make sure that you get a starter with the correct number of teeth on the starter gear.I THINK is should be a 14 tooth.Pretty sure that the Aluminum and Plastic ring gear used a 16 tooth starter gear.
Post the engine ID code and I'll look up a starter for ya.I would try to rebuild it.Bushings and brushes are easy to replace.And the New starters are Very Very cheaply made.The windings in the new ones are 1/4 the size of a NOS starter.
Edited by EricFromPa, August 29, 2013 - 07:54 PM.
#7 UncleWillie ONLINE
  • 14,983 Thanks
  • 8,515 posts
Posted August 29, 2013 - 10:27 PM
Yep it is a Briggs. I wonder how many different badges those little MTDs actually wore. That statesman is a new one on me.
#8 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted August 30, 2013 - 08:09 AM
No numbers on the shield that I can see. Hopefully I can get to it this weekend, get the side panels off and find some numbers
#9 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 9,731 Thanks
  • 5,421 posts
Posted August 30, 2013 - 08:33 AM
Sure looks like a Briggs but the air cleaner is different..  Take a look HERE
#10 TAHOE OFFLINE
TAHOE
  • 7,740 Thanks
  • 5,580 posts
Posted August 30, 2013 - 09:19 AM
Yep, Briggs, just replaced one on my 14 hp the other day. I had a spare lying around, found out they have different thicknesses of mounting plates, had to shim the newer one as it was thinner.
I have a 12/38 Weed Eater just like yours other than front sheet metal.
