Found A Carb For My 600, Need Linkage Pic . . .
16 replies to this topic
#1 PetesPonies OFFLINE
PetesPonies
  • 32 Thanks
  • 40 posts
Posted August 29, 2013 - 05:12 PM
SO I got an updraft carb for my 6hp B&S in the Bolens Husky. The carb looked like a perfect match (black carb ) except I had to change the throttle shaft as the connection for the linkage to the governor was in the wrong direction. So I switched the entire shaft. Now on the other end of the shaft, the throttle connects to the cable setup via another small linkage piece I believe. My blurry pic shows the end of the throttle shaft ( in red circle ) and an arrow to where the linkage piece would go ( and where my throttle cable attaches). Does anyone have a good pic of what this linkage piece looks like?? Thanks
#2 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted August 29, 2013 - 08:41 PM
Tell me about your engine and I can check for you.  What model do you have?
Ben W.
#3 PetesPonies OFFLINE
PetesPonies
  • 32 Thanks
  • 40 posts
Posted August 30, 2013 - 11:29 AM
142301 . .  original engine for a 1964 600 Husky. Thanks
#4 PetesPonies OFFLINE
PetesPonies
  • 32 Thanks
  • 40 posts
Posted September 01, 2013 - 09:42 AM
no one?
#5 Newpaws493 OFFLINE
Newpaws493
  • 1,368 Thanks
  • 1,811 posts
Posted September 01, 2013 - 10:57 AM
:anyone:
#6 Bolens 1000 ONLINE
  • 15,297 Thanks
  • 18,236 posts
Posted September 01, 2013 - 11:03 AM
Best I can do at the moment....
  • MH81 and Newpaws493 have said thanks
#7 PetesPonies OFFLINE
PetesPonies
  • 32 Thanks
  • 40 posts
Posted September 01, 2013 - 05:49 PM
Well you definitely have the goods   :thumbs:    If I could get you to dig in there a bit for a pic  .  . . .  that would be helpful. Here's a clearer pic of what I need,, but I'm sure you understand.
Edited by PetesPonies, September 01, 2013 - 05:49 PM.
#8 PetesPonies OFFLINE
PetesPonies
  • 32 Thanks
  • 40 posts
Posted September 03, 2013 - 07:07 PM
still need a pic of the linkage or the linkage piece if anyone has one to sell.
#9 MH81 OFFLINE
Posted September 04, 2013 - 06:36 AM
Are there any other Briggs engines that have the same carb? I have a model 19 I could get at that hasn't been muddled around with tht I know of.
#10 PetesPonies OFFLINE
PetesPonies
  • 32 Thanks
  • 40 posts
Posted September 04, 2013 - 02:36 PM
I'm sure there are. If you see in my pic, the carb I have is black, not the gold. so it came from something else. But I'm not sure if the throttle cables mount the same. If you look at the pic from Dr Bolens, you see there is a 5 sided gold sheetmetal piece next to the air cleaner. That is where the cable and linkages mount. The piece I need goes from the carb over to that piece , which is where the throttle cable is mounted.
#11 PetesPonies OFFLINE
PetesPonies
  • 32 Thanks
  • 40 posts
Posted September 08, 2013 - 09:07 PM
bump
#12 PetesPonies OFFLINE
PetesPonies
  • 32 Thanks
  • 40 posts
Posted September 10, 2013 - 04:18 PM
It would be nice to get this tractor up and running, but I can't do it without the throttle linkage. Just a pic would suffice.
#13 Bolens 1000 ONLINE
  • 15,297 Thanks
  • 18,236 posts
Posted September 10, 2013 - 04:33 PM
Let me take another look and see what I can find.....
#14 Bolens 1000 ONLINE
  • 15,297 Thanks
  • 18,236 posts
Posted September 10, 2013 - 06:09 PM
Here you go :thumbs:
  • MH81, drbish, PetesPonies and 1 other said thanks
#15 PetesPonies OFFLINE
PetesPonies
  • 32 Thanks
  • 40 posts
Posted September 10, 2013 - 10:33 PM
Thanks!! so the linkage is a spring? The connection from throttle plate to cable is a spring??
Edited by PetesPonies, September 10, 2013 - 10:33 PM.
