Yes that is how I plan to do it. Here is my first shop / shed, It seemed a LOT easier.http://www.youtube.c...h?v=vBnJL8WXnLw
Sorry about the crazy efficts I was new to the software.
Posted September 11, 2013 - 08:50 PM
Posted September 11, 2013 - 10:46 PM
Oh, and it never fails, I only went in for epoxy, and the new saw blades seemed to jump in my hand.
Posted September 12, 2013 - 10:46 AM
On the upside, impulse buys can't be figured into the budget
Oh yes they can....I just make an estimate on a project, then multiply by 2.
Posted September 12, 2013 - 04:14 PM
That's how I do every project !!
Posted September 12, 2013 - 08:37 PM
Multiply by 3 then you may break even
Posted September 12, 2013 - 08:43 PM
It's x2 if YOUR project..... x3 if it's the Wife's project!
Posted September 12, 2013 - 08:46 PM
Wife projects have no budget. That way she can't complain about tractor budget
Posted September 12, 2013 - 09:10 PM
Anchor bolts are in (phew) I may have to re-do the first two, The Anchor adhesive comes with 2 mixing spouts for a reason. I followed the instructions and squezed the gun once and discarded the first batch, then proceeded. I wanted to do this when the sun went down but the prep took longer than planed, any how the tube pluged up on the second hole (epoxy was almost black) I switched to the second tube and the rest went fine. I think I can use the compression bolts on the first two instead of opening the second tube of epoxy. The bolts are at 3" and the drilling went fine. The concrete feels good and stiff, and at 3" the drilling gets labored. I am calling tomorrow to schedule delivery of the tin. Oh and one other thing, I wish I had found these links 6 months ago. I am short on wood for the furings, and there are a lot of good tips.
http://www.youtube.c...h?v=jlAj-pLksMg
I'm book marking all of these for reference. This may be a long process over the winter due to funding.
Posted September 12, 2013 - 09:32 PM
Tomorrow I plan to wire brush all the bolts, then place the bottom wall boards back on to check the fit, and tighten the bolts down to check the hold. I didn't do the front wall where the doors will go. I;ll wait till I have them so I can cut the treated boards to the correct length then anchor them.
Posted September 12, 2013 - 09:43 PM
When you are done you can bring all the experience up here and build me one. I will even let you pay for it.
Posted September 13, 2013 - 08:32 PM
I put the bottom boards back on and sinched them up tight. All the bolts are holding well. Tin will arrive next Friday. I plan to get two corner walls up tomorrow. I may have to fight a little to get them lined back up on the anchors, but not too much "hopefully"
All the recharabiles are on charge tonight.
Posted September 14, 2013 - 08:07 PM
Larry, do ya want me to change the title for ya?
Posted September 14, 2013 - 08:26 PM
Yes please, I am past the need for concrete help, and I think others want to continue to follow the build. Something like (New Texas Shop) will work as I am using "Texas Man Cave" over there.
Posted September 15, 2013 - 05:12 PM
Ok The title of this needs to be changed to "The New Shop". I'll keep posting updates here. Walls are going up! Yaa!
I changed it to what you asked for! Looking good from Collinsville!
