The New Shop
580 replies to this topic
#376 MH81 OFFLINE
Posted February 05, 2014 - 10:41 PM
Nice of you to give him a place to work on it. Since he had to fold mirrors to get it in there, mention the next car is gonna need to be smaller.
#377 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted February 05, 2014 - 10:59 PM
HaHa, I need to test fit mine now. I thought the 6' would be wide enough. I think the Camery anf Ranger will fit, but I need to see.
#378 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted February 06, 2014 - 03:43 PM
Kids, especially the grown ones! I gave my Daughter my old car awhile back, she literally drove the wheels off it! This is the only way I could catch it to replace the tires, and donut, change the oil, and replace the brakes, and give it a overall check for it's 285,600 mile check. I won't see it again until she calls and says it's broke down on the side of the road again. :deadhorse:
  • Alc, KennyP, WNYTractorTinkerer and 1 other said thanks
#379 KennyP ONLINE
  • 37,451 Thanks
  • 45,472 posts
Posted February 06, 2014 - 04:03 PM
Looks like she got FULL use out of those tires!
  • olcowhand, larrybl and WNYTractorTinkerer have said thanks
#380 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted February 06, 2014 - 04:12 PM
And my bank account,
  • olcowhand, KennyP, HDWildBill and 1 other said thanks
#381 KennyP ONLINE
  • 37,451 Thanks
  • 45,472 posts
Posted February 06, 2014 - 04:24 PM
:bigrofl:
I know all about that! My daughter says "I'll give you some money when I get paid". Still waiting for her to get paid years later!
  • olcowhand, Alc, HDWildBill and 2 others have said thanks
#382 HDWildBill OFFLINE
  • 8,975 Thanks
Posted February 06, 2014 - 04:30 PM
:bigrofl:
I've heard that before as well. Still :tapping_fingers:   :bigrofl:
  • KennyP, boyscout862 and WNYTractorTinkerer have said thanks
#383 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted February 06, 2014 - 08:13 PM
She stopped by to pick up the car and asked "how much do I owe you" ...... I said "including the tow a year ago, and the monthly insurance I keep on it"? She has got that (Woman head toss) down pat. Mom added the receipts to the fridge magnet. I think I need a stronger magnet.
kids
  • olcowhand, Alc, KennyP and 4 others have said thanks
#384 UncleWillie ONLINE
  • 15,525 Thanks
  • 8,706 posts
Posted February 06, 2014 - 08:53 PM
Larry with enough grease and speed any vehicle will fit through that door.
I thought my tires were bad. I feel much better about the racing slicks now.
  • larrybl, WNYTractorTinkerer and oldedeeres have said thanks
#385 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted February 06, 2014 - 09:09 PM
As you might guess it's been slow going on the Shop due to weather and vehicle issues. I have been fighting leaks around the windows. I foamed them, calked them, and even tried "Mighty seal" what a waste. I think I found my problem though. I did not install the trim properly. I need to pick up some more trim and cut out all the foam and calk. This time I need to install the bottom first, then the sides to overlap the bottom, then the top to overlap the sides. I originally installed the top first and worked my way down.
  • MH81, Alc and boyscout862 have said thanks
#386 oldedeeres OFFLINE
oldedeeres
  • 9,148 Thanks
  • 4,630 posts
Posted February 07, 2014 - 01:47 AM
Yup, kind of like shingling, start at the bottom and work your way up.
  • larrybl said thank you
#387 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted February 08, 2014 - 09:35 PM
Well, I attempted reworking the window trim to fix the leak issue. I cut the foam and calk out and pulled the trim off, when cutting the foam there was a lot of water being held in. I made a couple test strips to assist with measuring. This time I started at the bottom and worked my way up overlapping the trim. I used the sides to make new top and bottoms, and used new trim for the sides. I then re calked it in. I'll hold off on re foaming the inside as I don't trust this fix. If it continues to leak I may need to call in professional help again.
  • MH81, Alc and oldedeeres have said thanks
#388 MH81 OFFLINE
Posted February 08, 2014 - 10:57 PM
Looks like you're good now Larry.
#389 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted February 08, 2014 - 11:00 PM
We'll see, rain is forecasted for next week.
#390 Sawdust OFFLINE
Sawdust
  • 5,562 Thanks
  • 3,335 posts
Posted February 09, 2014 - 01:15 AM
Looking at some of your pics you have several water leaking issues. If your not using J trim around your windows & doors your going to still leak. You start with the bottom, top, then the sides. It's hard to see but your windows look like their recessed a little too much. I want to address some things based on all the foam you have on the inside. Did you apply any type of sealant on the bottom of your sill plates before you fastened them to the concrete? Did you also run a bead of sealant in front of the plate where it meets the concrete before you installed your panels? Is your front concrete pad sloped away from your front wall? Did you install eave flashing & it looks like you don't have enough or any over hang. These areas not done right will cause water issues where you have all the foam on the inside like where the roof meets the walls, around your windows & at the base where your walls meet the floor. I commend you for your motivation & the willingness to build your own shop. I still think you need a coffee pot in there somewhere....it looks cozy.  :thumbs:
  • HDWildBill and oldedeeres have said thanks
