Got a break from the rain, and did some shopping for electrical. I have some things picked out. I started back on the trench to the power pole, and decided to look inside the meter box. Not sure how I am going to tie in #4 wire to these. Looks like #2 or #0 and the existing lugs are full. I do have access to the netrual. Is there an adapter I can use on these?
The New Shop
#256
OFFLINE
Posted November 07, 2013 - 06:03 PM
#257
OFFLINE
Posted November 07, 2013 - 07:15 PM
I have seen adaptor/extensions that would work for you.
Just not sure where I've seen them.
- larrybl said thank you
#258
ONLINE
Posted November 07, 2013 - 07:23 PM
Where's NJKen when you need him? Bet he knows how to make that work!
#259
OFFLINE
Posted November 07, 2013 - 07:28 PM
I think I found what I need..... Still doing research on these. I need to determine the feeder wire size so I can tap this 4/0-4/0-2/0 Aluminum URD Service Entrance Cable (By-the-Foot) $1.89 ft
cable into it.
http://news.thomasne...ion-time-539065
#260
OFFLINE
Posted November 07, 2013 - 07:48 PM
All the sites visted either want me to but a $150.00 minimum or charge $85.00 apeice for these.
#261
OFFLINE
Posted November 07, 2013 - 08:33 PM
What I did is I had power already run to one building so I tapped off that panel and ran #8 to my new shop. Not sure about how well your home depot is but the guys in mine were quite knowledgeable and great to work with. You might be surprised what they will come up with.
- boyscout862 said thank you
#262
OFFLINE
Posted November 07, 2013 - 09:56 PM
Existing home is a single wide mobile home, and the panel is full. Plus I am planning to replace it in the near future with a doubble wide. I would like the shop to have it's power seperate.
- boyscout862 and oldedeeres have said thanks
#263
OFFLINE
Posted November 08, 2013 - 01:41 AM
That's a smart move in my book, having the power separate. You never know how much drain you may be putting on in the shop when there is already lots going on in the house. In my experience, wives can get pretty upset over things like that, lol
- Alc said thank you
#264
OFFLINE
Posted November 08, 2013 - 06:33 AM
Larry by having seperate services wouldn't that cost more ? Here we pay a basic service charge then the first so many kilowatts the price is the highest 700 comes to mind then gets a little cheaper . Is that a 200 amp service ? Notice I'm cheap lol
#265
OFFLINE
Posted November 08, 2013 - 09:20 AM
Alc, it is a 200A service, and as far as I know there won't be any additional cost as I will be comming off the same metered service. With that said.... I will purchase the wire, breaker box, conduit, and get it all laied in except for the final connection to the main service and call an electrition to complete the connection. If I need a 100A disconnect added I'll let him make that decision.
Thanks all.
- Alc and oldedeeres have said thanks
#266
OFFLINE
Posted November 08, 2013 - 09:32 AM
I have saved money years ago by salvaging a temporary service from a commercial job site. 150 feet of 4 strand #2 cable,the meter box, and the curcuit box all on a 6 x6 pole. They were just throwing it away. Good Luck, Rick
#267
OFFLINE
Posted November 08, 2013 - 10:01 AM
- Alc and boyscout862 have said thanks
#268
OFFLINE
Posted November 08, 2013 - 10:58 AM
Separate power is the best idea.
We originally had dads garage wired into the house power. When we were out there welding it would dim the lights in the house when you struck an arc.
#269
OFFLINE
Posted November 08, 2013 - 03:41 PM
Sorry I missunderstood you , I thought your were looking into a seperate service ( different meter )
#270
OFFLINE
Posted November 08, 2013 - 06:40 PM
I talked with an electrtian today. I will install a 100A breaker box in the shop, go underground with 4/0-4/0-2/0 Aluminum URD Service Entrance Cable to the pole and install a 100A fused disconnect box below the main service. He will then tap the existing service cables and connect to the 100A disconnect.
Meter--> 200A Breaker-->1.5' cable--> 100A Disconnect--> 39' cable--> 100A breaker panel.
- MH81, Alc, sacsr and 4 others have said thanks
