The New Shop
#196
OFFLINE
Posted October 06, 2013 - 09:33 AM
- JRJ said thank you
#197
ONLINE
#198
ONLINE
Posted October 06, 2013 - 07:19 PM
Getting close, Larry! Looks great from Tulsa area!
- larrybl and JRJ have said thanks
#199
OFFLINE
Posted October 06, 2013 - 07:23 PM
Yep it's getting close. Are you going to set up your work bench, install installation and run electrical before moving in?
#200
ONLINE
Posted October 06, 2013 - 07:28 PM
The electrical - insulation - Work bench budget was eaten up with the slab repair. But all that can be done a little at a time over the next couple years. I still need to purchase a good 36" walk in door..... any suggestions? Lowes and Home Depot are the closest stores.
- oldedeeres and JRJ have said thanks
#202
OFFLINE
Posted October 06, 2013 - 09:12 PM
#203
ONLINE
Posted October 06, 2013 - 09:19 PM
Weather looks good this week, but I only have a couple hours after work to work on this. I need a new battery for my drill as I need 2. One to drill the top ridge pilet hole and the other to sink the fastining screw. Hope next weekend is as good as this. I may even have the doors on.
- HDWildBill, oldedeeres and JRJ have said thanks
#204
ONLINE
Posted October 06, 2013 - 09:33 PM
Larry, if I built anything without making some sort of mistake like tin alignment, I think I'd have a heart attack! Looks great from here. One question though....with not having overhang at the drip edge, did you put the sealing foam under the roof panels to prevent water from creeping/blowing up onto the wood?
- larrybl, oldedeeres and JRJ have said thanks
#205
OFFLINE
Posted October 06, 2013 - 10:08 PM
Looking good Larry. I wouldn't be too concerned about that little misalignment.
That's why they make trim.
I always get a chuckle when talking with a builder or framer, and they say that
"so and so" is a good trim carpenter, and talk about him like he's a god.
That's because "so and so" is real good at covering/hiding their mistakes, and
rescuing them.
- Alc, boyscout862, twostep and 2 others have said thanks
#206
OFFLINE
Posted October 07, 2013 - 05:40 AM
For how much problems you had at the begining it's looking great here at the end , looks like a it was put up by a contractor
#207
ONLINE
Posted October 07, 2013 - 07:23 PM
Yes i used the pre-formed foam under the edges, and plan to fill all the edges (including the ones with foam) with the expanding foam in a can.
- olcowhand, KennyP and JRJ have said thanks
#208
ONLINE
Posted October 07, 2013 - 07:24 PM
Tonight's progress, 4 more roof panels, 3/4 done and "0-Accidents". Man it is starting to get dark early. Thanks for the comments. If wondering I am saving the front wall to last as it will be the most technical with the two doors.
- MH81, IamSherwood, oldedeeres and 1 other said thanks
#209
ONLINE
Posted October 07, 2013 - 07:27 PM
Just use the 'low expansion' foam. That front wall will be the hardest, but you now have sheet metal experience. You'll do fine!
#210
ONLINE
Posted October 07, 2013 - 09:15 PM
Side note: Once I am done I'll use "Movie Maker" to do a beginning to end with the best pictures. A little birdi told me Windows XP will become non-supported earily next year so Movie maker will be obsolete.
