The New Shop
580 replies to this topic
#181 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7905 Thanks
  • 4734 posts
Posted September 29, 2013 - 09:15 PM
I hear that. I am a little concerned about the un-treated lumber going through several rain epasodes before I can get the tin on. Seems like we are in a hot dry spell through the work week with rain fronts on the weekends.
  • JRJ said thank you
#182 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted September 29, 2013 - 09:24 PM
The wood will be fine I would think.  We've built stuff that left wood exposed a while with no ill effects at all.
  • larrybl and JRJ have said thanks
#183 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7905 Thanks
  • 4734 posts
Posted September 29, 2013 - 09:35 PM
Thanks, I was hopeing so as it is taking me a while to do this by my self.
#184 KennyP OFFLINE
  • 52007 Thanks
  • 52952 posts
Posted September 30, 2013 - 03:00 AM
Looking good, Larry! The wood will be fine!
#185 toomanytoys84 OFFLINE
toomanytoys84
    Aaron
  • 11574 Thanks
  • 6736 posts
Posted September 30, 2013 - 07:08 AM
I'll be 55 next month.  I've dropped 30lbs since doc said I had diabetes.  Heartburn is gone after the weight loss.  But still lots slower than I was ten, even 5 years ago.  A lot of the slowing is due to the meds keeping me tired.
My dad will be 55 in May.  His meds are slowing him down as well.  Sad the meds that help you end up making you feel worse at times.
  • oldedeeres and JRJ have said thanks
#186 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7905 Thanks
  • 4734 posts
Posted September 30, 2013 - 06:52 PM
I guess I am a glutton for punishment, Last day of the budget year at work so nothing really to do. I put in for 7 sick hours and came home and spent a full day at work here. Finished the roof perlings and hung a couple sheets of tin, then I took a shot at installing a window....... Going on youtube tonight to figure out the right way to add the trim.
  • KennyP, sacsr, bgkid2966 and 4 others have said thanks
#187 HDWildBill OFFLINE
  • 8994 Thanks
  • 8664 posts
Posted September 30, 2013 - 07:01 PM
Coming along nicely Larry.
#188 oldedeeres OFFLINE
oldedeeres
  • 15095 Thanks
  • 6744 posts
Posted October 01, 2013 - 01:14 AM
I like the colour, not the usual grey or white we see up here. Looks nice!
#189 KennyP OFFLINE
  • 52007 Thanks
  • 52952 posts
Posted October 01, 2013 - 04:54 AM
That is good to hear. Hope it goes smoothly!
#190 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted October 01, 2013 - 06:00 AM
Hard to tell in the pictures. Does the concrete slope down hill outside of the
bottom plate?
If not, you should put flashing behind the siding, to cover the concrete, otherwise
you'll have rainwater leaking in under the bottom plate.
Good to see your making good headway.
Just went back and looked at some pics I missed.
I now see, that the bottom plate is right at the edge of the
slab. All is well. :thumbs:
Edited by IamSherwood, October 01, 2013 - 06:14 AM.
#191 bgkid2966 OFFLINE
bgkid2966
  • 1415 Thanks
  • 1331 posts
Posted October 01, 2013 - 06:52 PM
Looking great!! That is going to be a great shop to play in!! :thumbs:
Geno
#192 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7905 Thanks
  • 4734 posts
Posted October 01, 2013 - 08:01 PM
Not much to report, I had to add a top wall perling to screw the top of the tin in, Removed the window so I could mark the next sheet of tin to be cut. then it got dark and the mosquetos came out. :mad2:
  • KennyP, HDWildBill, oldedeeres and 1 other said thanks
#193 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7905 Thanks
  • 4734 posts
Posted October 05, 2013 - 05:55 PM
Wasn't sure if the weather was going to cooperate as a cold front hit, man I had a time with the tin. But..... Progress :dancingbanana:
With all the moving around the "mobile work bench" I think I need to rebuild HulkII Starter, it is starting to drag.
  • KennyP, boyscout862, twostep and 3 others have said thanks
#194 KennyP OFFLINE
  • 52007 Thanks
  • 52952 posts
Posted October 05, 2013 - 07:05 PM
Looking good, Larry. On the 'mobile work bench', move it to a corner. Then you can do 2 sides before you move it!
#195 HDWildBill OFFLINE
  • 8994 Thanks
  • 8664 posts
Posted October 06, 2013 - 08:52 AM
Really starting to take Shape Larry.
