The New Shop
580 replies to this topic
#136 Sawdust OFFLINE
Sawdust
  • 5,563 Thanks
  • 3,335 posts
Posted September 18, 2013 - 12:26 PM
That is why I like these forums, Thanks Twosteps :thumbs: I was going to add two more 2X6X18's for a total of 4 and the ladder on top. I liked the truss idea, and it was fun to build. Just lay a 2X4 across the hole, mark the angle inderneath, cut, and add 4 3" decking screws. This should work. Plan on braceing the ends to the walls.
I'm confused...is this what your going to use for a ridge beam, if so it won't work.
#137 Sawdust OFFLINE
Sawdust
  • 5,563 Thanks
  • 3,335 posts
Posted September 18, 2013 - 12:51 PM
I guess where I'm confused is your talking about rafters & no discussion about ceiling joists. A center beam for ceiling joists on top like you have pictured would be ok but not typical. I would as mentioned go with a laminated beam. If you do use the "ladder" method place metal gussets across ALL your 2x4 joints both sides. I would also like mentioned glue your sheathing on both sides as well. The reason your "ladder method" is not typical is it's not engineered to carry a tremendous load vertically & will cost probably a lot more than a laminated beam. Don't get discouraged there is a lot you need to do now. Double plate the top of your walls. I would sheet the walls this will prevent any racking. Brace exterior walls every 8' good with stakes. This will prevent any walls going out of plumb when you fasten your rafter tails. Let your rafter tails run wild, decide on your soffit dimension, snap chalk line on top & cut all the same length. Keep us informed on what your doing   :thumbs:
  • larrybl, boyscout862, twostep and 1 other said thanks
#138 shorty ONLINE
shorty
  • 5,288 Thanks
  • 5,169 posts
Posted September 18, 2013 - 08:33 PM
Your truss is came together nice. One thought I had was, if you would flip it around so that the first diagonal brace would sit down to your bearing point. In the picture it is starting at the top and and then the diagonal force is pulling down from the top instead of pushing down and out to where it sits on the wall.
  • oldedeeres said thank you
#139 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,350 posts
Posted September 18, 2013 - 09:32 PM
Sawdust, thanks for the comments, I know this is not tradiotional but I'm trying. At this point I have nothing to sheet the walls with. Tin won't be here till Monday. Once it arrives I'll see if I have enough clearance to add the double plate to the top of the walls (I need to make sure the tin will hang ~ 1" below the top of the foundation. I like the idea of bracing the outer walls prior to installing the rafters (not sure what joists are).
Tonight's progress, I took the truss up and thought how in the he$$ was I going to ballance it on the two 2X6's. After pondering I resolved to disemble the truss and make it 24" tall instead of 18.5". The plan is to spread the 2X6's and place the truss in the center and screw the 2X6's to it (almost like what I currently have). I can still go back and add more 2X6X18's if needed.
Once I was done re-working the truss, I placed one end on the trailer and the other on the ground, stood it up and bounced my 250 lbs on the center, the only give I noticed was the trailer tire spring (this thing is stiff. Shorty, If the shop was 20' then both ends would be faceing down.
  • JRJ said thank you
#140 boyscout862 OFFLINE
  • 12,551 Thanks
  • 9,044 posts
Posted September 19, 2013 - 12:37 PM
If that beam is going down the center it should be designed to your local code. Around here, that would probably be 40 pounds per square foot. The beam supports 10 square feet per foot of length. That means that the beam should be designed for 400 pounds of load for every foot of length. 18 feet times 400 pounds per linear foot would be 7200 pounds. Your 250 pound test is not valid. Please be very carefull. If this collapses, someone could get killed.
Before going any further make sure the temporary bracing is adequate. You should also have diagonal bracing inlaid into the wall frame. This is very necessary because you are using wrinkle tin. Good Luck, Rick
#141 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,350 posts
Posted September 19, 2013 - 06:52 PM
Not sure there are local codes out here. There are some pretty shabby houses and buildings around. This shop was built Dec 2007 and is still holding up well. I plan on having 4 2X6 and the truss which will make 5 support beams down the center. Two more than the current shop. I appreciate the concern, and I will do my best to mahe sure it is supported well, but I don't think I will be hanging the Ford Ranger from the roof.
  • twostep, oldedeeres and JRJ have said thanks
#142 boyscout862 OFFLINE
  • 12,551 Thanks
  • 9,044 posts
Posted September 20, 2013 - 04:49 AM
Is the roof going to extend out over the slab in front? Good Luck, Rick
#143 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,350 posts
Posted September 20, 2013 - 06:18 PM
Maybe 1 to 1-1/2 but not much more.
#144 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,350 posts
Posted September 21, 2013 - 05:26 PM
Just so everyone knows..... The truss is installed! I have already been up on this measuring for the rafters, 140 1/2 on one side and 141 3/4 on the other. Not bad being 1 1/4" off, I;ll be able to even that up easily in the morning. Even tho this feels really stiff, I will be adding two more 2X6's later on.
  • oldedeeres and JRJ have said thanks
#145 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted September 21, 2013 - 06:25 PM
I built a truss similar to that to cover the 16 foot span over my garage door and laminated 3 layers of 7/16 osb on both sides using lots of construction adhesive and screws.
#146 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted September 21, 2013 - 06:39 PM
This is shaping up to be really nice.  You'll have to put a TV, couch, fridge and a bathroom in it!  That is all a guy needs, right?
#147 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,350 posts
Posted September 21, 2013 - 06:40 PM
I opted to use 2X6's to give this strength. the truss is primarly to add 2' to the ridge. Wasn't planning on the truss to be the primary support but with this configuration I can add more 2X6's.
#148 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,350 posts
Posted September 21, 2013 - 08:46 PM
I had rain the last couple days, It's 76 degrees in the old shop right now and I have cold chills and thinking of breaking out the heater.
#149 Cat385B ONLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted September 21, 2013 - 09:49 PM
I break out sweating at 76. Come on, 40's and 50's!
  • NJKen and JRJ have said thanks
#150 oldedeeres OFFLINE
oldedeeres
  • 9,173 Thanks
  • 4,642 posts
Posted September 21, 2013 - 10:50 PM
I'm with you! We have had several nights of below freezing already, and the garden is toast.
