Snow Blower Repair( I Hope)
14 replies to this topic
#1 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,968 Thanks
  • 9,614 posts
Posted August 28, 2013 - 01:01 PM
I offered to repair my neighbors snow blower. He has an MTD 10 hp walk behind, that needs a new multi-position bearing on the auger shaft. I n order to remove it I have to remove that 12" pulley. It is quite stuck and has no provision for a puller. I have tried everything to wedge it off. I've used PB Blaster and have now mixed up some ATF and acetone. I'm almost tempted to drill a couple of holes to install a puller, but this just seems like poor workmanship. Any ideas?
  • JRJ and OkieGt have said thanks
#2 Guest_gravely-power_*
  • Guests
Posted August 28, 2013 - 01:04 PM
Got a pic.? LD. I have had to drill and tap several pulleys, there was just no other way.
  • LilysDad, WNYTractorTinkerer and OkieGt have said thanks
#3 antiquetractors OFFLINE
antiquetractors
  • 280 Thanks
  • 506 posts
Posted August 28, 2013 - 02:26 PM
Pics would help so we can see what you're dealing with.
  • LilysDad said thank you
#4 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted August 28, 2013 - 02:47 PM
Air hammer on a block/piece of metal might loosen the pulley
#5 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 10,187 Thanks
  • 5,666 posts
Posted August 28, 2013 - 03:06 PM
If you can get a bolt behind it just drill three holes & use a puller with grade #8 bolts..  (& 'fire-wrenches' of course!)
  • LilysDad and OkieGt have said thanks
#6 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,968 Thanks
  • 9,614 posts
Posted August 28, 2013 - 03:07 PM
Does this help?
#7 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,968 Thanks
  • 9,614 posts
Posted August 28, 2013 - 03:10 PM
That's the option I'm saving for last. I've' been trying to wedge between the hub and collar you see in the picture and then hammer on  the end bolt with a block of wood and it just doesn't want to let go.
  • OkieGt said thank you
#8 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,187 Thanks
  • 5,666 posts
Posted August 28, 2013 - 03:20 PM
How big is the shaft??  (I'll wager it's one inch)..  A pickle fork should do the job and not distort the pulley..
#9 DougT ONLINE
DougT
    Dog Approved
  • 6,848 Thanks
  • 4,950 posts
Posted August 28, 2013 - 03:22 PM
There looks like plenty of meat in the hub to drill and tap for a puller. That and a little heat should do it.
#10 IHCubGuy ONLINE
IHCubGuy
  • 1,500 Thanks
  • 1,579 posts
Posted August 28, 2013 - 03:36 PM
What about using a large bearing seperator?  Maybe can rent one from a tool rental place.  I think the tin pulley is only gonna bend trying to get it off with three bolts if it is as tight as you are describing.  I never have great luck with those tin pulleys.
#11 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted August 28, 2013 - 03:59 PM
pickle fork and vibration such as a air hammer on  piece of buck stock metal, that might take an extra hand though
#12 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 12,968 Thanks
  • 9,614 posts
Posted August 28, 2013 - 05:13 PM
The pickle fork sounds like an idea. I'll have to see if I can borrow one. I don't have an air hammer or 'fire wrench'. This is a small time operation. :D
#13 JRJ ONLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted August 28, 2013 - 06:57 PM
good luck with getting the pulley off, all of the suggestions seem to be what you need to do.
Dick
#14 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 12,968 Thanks
  • 9,614 posts
Posted August 28, 2013 - 07:20 PM
I'll have to wait until I get to town and borrow a tool. I'll let you'se know.
#15 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,968 Thanks
  • 9,614 posts
Posted August 29, 2013 - 01:03 PM
The ball joint tool worked like a champ! Now,  if Amazon hadn't sent the wrong bearing, I would be almost done. :ah_shoot:
