Code Readers.
31 replies to this topic
#1 HDWildBill OFFLINE
  • 8,984 Thanks
Posted August 27, 2013 - 07:55 PM
I'm thinking about getting a Code reader to read the fault codes on our vehicles but looking at them they readers that will do something and not other then you have the deluxe model etc.  I'm hoping some of you automotive types can steer me in the right direction.  I just need a good one that doesn't cost a lot of $$$ that will tell me what is wrong.  Thanks
  • JRJ said thank you
#2 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,101 Thanks
  • 10,172 posts
Posted August 27, 2013 - 08:02 PM
Do you know that if you go to an Auto Zone, you can use one for free?
  • MH81, HDWildBill, boyscout862 and 1 other said thanks
#3 MH81 OFFLINE
  • 29,978 Thanks
Posted August 27, 2013 - 08:08 PM
Bill, if its a static problem. (Misfire, o2 sensor, etc) the basic HF units are what I've done.
The ones with real time recording and analyzation would be the bomb, but for the cost, I might as well take it to the shop.
LD, I didnt know that. Good to know.
  • HDWildBill said thank you
#4 HDWildBill OFFLINE
  • 8,984 Thanks
Posted August 27, 2013 - 08:23 PM
Advance Auto will also read it out.  From where we live it is a good drive to get to either auto zone or advance.  My truck has a problem with one of it's sensors I believe.  The engine RPM stays high and it doesn't want to shift correctly.  Years ago I has a similar problem with a Ford truck and it was a speed sensor.  Since I have 4 vehicles to help maintain I figured having a code reader would be a good tool to have on hand.
Alan, I was just looking at HF's readers and they have one for $82 that seems to be good.  It has some good reviews.  Thanks
#5 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted August 27, 2013 - 08:29 PM
I have one purchased from Amazon and it uses my laptop to display all codes and realtime info. It only cost about $25. This is the one I have.
 http://www.amazon.co...=obd ii scanner
I am very happy with it. It has worked on an 02 Pontiac and an 08 GMC. It supposedly works on all standard plug obd ii hook ups.
Geno
Edited by bgkid2966, August 27, 2013 - 08:30 PM.
  • MH81, Alc and HDWildBill have said thanks
#6 nra1ifer OFFLINE
nra1ifer
  • 674 Thanks
  • 1,531 posts
Posted August 27, 2013 - 09:02 PM
I have an Actron CP9125....   http://actron.com/pr...l.php?pid=16298
Seems like it was $70 or so. When I had my Windstar van, I needed on fairly often, so I finally bought one. I like it a lot.
  • MH81, Alc, HDWildBill and 1 other said thanks
#7 AVB OFFLINE
AVB
  • 138 Thanks
  • 135 posts
Posted August 27, 2013 - 09:05 PM
I have the same thing as bgkid, but I have bought some upgraded software. The free software is pretty good, but I had a problem with the eclectronic 4x4 on a F150 and needed better software to monitor the GEM module.
#8 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted August 27, 2013 - 09:08 PM
What software did you buy? Are you happy with the new software? An upgrade is something I have been considering.
Geno
#9 AVB OFFLINE
AVB
  • 138 Thanks
  • 135 posts
Posted August 27, 2013 - 09:14 PM
I bought the professional add on for OBDwiz, but it wasn't much better than the trial version. ScanXL from Palmer Engineering is the best one I have tried yet, but can be a pain figuring it out. If I just want to check codes and basic data I use the free Scantool.net software, it is quicker.
#10 MH81 OFFLINE
  • 29,978 Thanks
Posted August 27, 2013 - 09:32 PM
The obd to USB looks cool Bill. I wonder if it cares what OS you're using tho? If it has to be win or Mac, some Linux guys may not want to do this.
#11 Arti ONLINE
Arti
  • 1,371 Thanks
  • 995 posts
  • Location: South West Wisconsin . Now in North Central Mo.
Posted August 27, 2013 - 09:41 PM
I use this with an android smart phone. and use free software for it.
www.ebay.com/itm/390619561505?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Also have one that is just a basic reader that I paid $40. for and it is really basic the android one is much better for me.
#12 boyscout862 OFFLINE
  • 13,545 Thanks
  • 9,425 posts
Posted August 27, 2013 - 11:19 PM
Bill, I bought an OBDII scan tool from NAPA a couple of years ago for $50 on sale. It gives the basic codes, erases, and gives the status of the monitoring system. It has paid for itself already because in CT you have to have your car emmissions tested every two years. My cars being older keep flunking. I had to replace a cat last week.
Many cars have a way to read the codes by turning the ignition switch on and off several times. I'll get the brand and model of my scanner tomorrow. Good Luck, Rick
#13 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted August 28, 2013 - 01:22 AM
Wow, prices have really came down over the years.
#14 smokestack76 OFFLINE
smokestack76
  • 83 Thanks
  • 86 posts
Posted August 28, 2013 - 02:35 AM
If you have a android phone this is a good one https://play.google....rg.prowl.torque
Buy a bluetooth obd plugin off amazon for 10 bucks and your set!
#15 Alc ONLINE
  • 7,221 Thanks
  • 7,576 posts
Posted August 28, 2013 - 05:01 AM
With those scanner/code readers under. $ 100. It makes sence if you use it just a few times
