682 starter not engaging
18 replies to this topic
#1 Super 982 OFFLINE
Super 982
  • 13 posts
Posted November 27, 2010 - 03:32 PM
I've noticed lately when I start my 682 (Kohler twin KT17S) that the starter does not engage all the time. It spins, then I turn ignition off and try again and it engages and starts right up. Sometimes I need to try 3 or 4 times. Is there a fix for this - lubrication, etc.? Man, that starter is down under that engine - hope the engine need not be removed to work on the starter.
#2 Bolens 1000 ONLINE
  • 15,423 Thanks
  • 18,279 posts
Posted November 27, 2010 - 03:54 PM
Sounds like it may need to be cleaned....
#3 caseguy OFFLINE
  • 1,629 Thanks
Posted November 27, 2010 - 06:07 PM
I'd say that Brian is probably right. There should be a small panel that can be removed without taking ALL of the shrouding apart. I would just use compressed air and blow out the gear and slide mechanism and then shoot some aerokroil or blaster in there. Work it a few times before you put the cover back on to make sure you got it good enough.
#4 MH81 OFFLINE
  • 29,978 Thanks
Posted November 27, 2010 - 06:27 PM
You may want to blow it off again after you get it functioning properly.
The more extra lubrication you have, the more dirt will stick to it & cause add'l problems.
Fine line between too much & not enough.
#5 olcowhand OFFLINE
  • 42,896 Thanks
  • 31,939 posts
Posted November 27, 2010 - 06:54 PM
Another thing to check. I have had starter drives stick like this and lubing helped for just a little while, then sticking all over again. What I found, is the starter drive, where it bottoms on the starter shaft "step up" when the starter drive returns to rest position....it will wear slightly into the base of the starter drive & cause a binding, locking it in place. What I do is carefully grind the bottom of the starter drive base until the shaft wear depression disappears. Once I do this, the starter drive never hangs up again.....unless it wears down into there again, which has never happened to date. Takes years to create the wear needed to bind it up.
#6 mjodrey OFFLINE
Posted November 27, 2010 - 06:58 PM
Yes cleaning may help,sounds the bendix is sticking and not engaging the flywheel sometimes.If you take it off to clean and /or lubricate it,make sure you bench test it before you put it back on.
#7 MH81 OFFLINE
  • 29,978 Thanks
Posted November 27, 2010 - 08:21 PM
Would a shim washer between the 2 help/or do the same thing?
#8 Bolens 1000 ONLINE
  • 15,423 Thanks
  • 18,279 posts
Posted November 27, 2010 - 08:26 PM
Good thinking
I did that once and it worked
#9 olcowhand OFFLINE
  • 42,896 Thanks
  • 31,939 posts
Posted November 27, 2010 - 08:46 PM
Will do fine, if a hard tempered washer. A soft one doesn't last long. I have to have the drive off anyway, so I just grind it down. The less moving parts the better I figure.
#10 MH81 OFFLINE
  • 29,978 Thanks
Posted November 27, 2010 - 09:11 PM
One of the reasons I love the older stuff. :D
#11 Alc ONLINE
  • 7,226 Thanks
  • 7,578 posts
Posted November 27, 2010 - 09:12 PM
Maybe you already did this but make sure you have 12 volts and good ground right at the starter , had a problem on my JD , starter spun but didn't engage the engine , turned out a bad connection .
#12 Super 982 OFFLINE
Super 982
  • 13 posts
Posted November 27, 2010 - 09:32 PM
Many thanks to all who contributed info on my starter concern. I'm banking on blowing it out with air and checking the ground wire - which is visible and reachable. Anything else would mean removing the engine - yikes!
#13 Bolens 1000 ONLINE
  • 15,423 Thanks
  • 18,279 posts
Posted November 27, 2010 - 09:34 PM
Keep us posted
#14 NUTNDUN OFFLINE
  • 10,352 Thanks
Posted November 27, 2010 - 09:43 PM
It sucks when you have to pull the engine to replace something as easy as a starter. I hope the clean up and the ground wire fixes it for ya.
#15 Super 982 OFFLINE
Super 982
  • 13 posts
Posted November 28, 2010 - 09:17 AM
Freezing cold here today. Warmer tomorrow and I'll get at the starter problem then - keeping all posted here. Again - thanks for the feedback and solutions.
