Need Help With Older Briggs Model Number
4 replies to this topic
#1 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted August 27, 2013 - 01:08 PM
Ok so on my girlfriends MTD it has a briggs motor but the hp sticker is worn off. I am able to get the serial number off the engine shroud and it reads this.
32643 0228 -01 7706021......Is this correct? Thanks in advance guys :wave:
#2 DougT ONLINE
DougT
    Dog Approved
  • 6,846 Thanks
  • 4,949 posts
Posted August 27, 2013 - 01:21 PM
My guess would be model 32643  Type 0228 -01  Code 7706021.
That would make it a 32 cu in engine (16 hp) built in 1977. Does that sound close?
  • hamman and Dieselcubmike have said thanks
#3 HDWildBill OFFLINE
  • 8,975 Thanks
Posted August 27, 2013 - 01:24 PM
I think you are correct Doug.  According to the attached ref it is a 16HP
Attached File  2012_Engine_Model_Number_Guides.pdf   712.06KB   23 downloads
  • Dieselcubmike said thank you
#4 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted August 27, 2013 - 01:25 PM
yes it does thank you doug! I know it says 16hp on the side of the tractor but im not very good with serial numbers so I figured someone could help me out on here
  • 14,730 Thanks
  • 15,470 posts
Posted August 27, 2013 - 01:26 PM
If I have it right, 32 CID,16hp,. Are you sure about the 3 at the end because that stands for 110 electric start only.
