1972 Jd 110 With A 5Hp Honda Motor In It. Is It Possible?
3 replies to this topic
#1 Betty Humpter OFFLINE
Betty Humpter
  • 13 Thanks
  • 29 posts
Posted August 27, 2013 - 09:22 AM
I just got a 1972 JD 110 with a bad kohler motor.  I plan on rebuilding it over the winter, but i wonder if i could temporarly put a honda 5hp ohc motor to get me through the rest of the grass cutting season?
has anyone done this before?
  • JRJ said thank you
#2 JDBrian OFFLINE
  • 9,594 Thanks
Posted August 27, 2013 - 09:56 AM
I dont think you'd have enough power to run the mower unless it was at very low ground sped.
#3 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,034 Thanks
  • 1,457 posts
Posted August 27, 2013 - 10:47 AM
I don't think it would be worth the trouble of adapting it to fit if it's not permanent. You should just buy another tractor :D  What happened to the Kohler?
#4 Betty Humpter OFFLINE
Betty Humpter
  • 13 Thanks
  • 29 posts
Posted August 27, 2013 - 12:16 PM
The piston went bad, and it ejected the spark plug. i am going to rebuild it over the winter.
