Wife Will Be Mad... I Just Got A 1972 Jd 111 That Has A Bad Engine...
7 replies to this topic
#1 Betty Humpter OFFLINE
Betty Humpter
  • 13 Thanks
  • 29 posts
Posted August 27, 2013 - 07:10 AM
Its a 1972 110 with a bad kohler 8hp engine in it.  The owner said that the piston wont move in the engine and it still turns over.  The spark plug was also ejected at the time of the death.  Can i swap out a 5hp honda engine in it until i get the kohler rebuilt?
This mower just had the deck refinished 2 years ago.  its in really good shape.
this is my second tractor purchase this summer....
Edited by Betty Humpter, August 27, 2013 - 10:39 AM.
#2 jms180 ONLINE
jms180
  • 1,750 Thanks
  • 1,674 posts
Posted August 27, 2013 - 07:20 AM
I don't know about the engine swap but I know the wife will be out shopping for new shoes.
  • Alc and IamSherwood have said thanks
#3 Trav1s ONLINE
Trav1s
  • 3,578 Thanks
  • 4,554 posts
Posted August 27, 2013 - 07:54 AM
Just to clarify - you are talking about a 1972 110, right?  The 111 is a later machine with a vertical shaft engine in it.
I am sure you could do a China honda "Chonda" swap.  I have seen them on other forums in both the '68-'74 110/112 (easier on the later ones IIRC) and the 200 series machines.  Do you intend to use attachments?  The clutch can be a challenge in this swap.
Have you considered finding a good k181 to swap in?
And just to be obnoxious...
:picsoritsnotyours:
Edited by Trav1s, August 27, 2013 - 07:57 AM.
  • jd.rasentrac said thank you
#4 Betty Humpter OFFLINE
Betty Humpter
  • 13 Thanks
  • 29 posts
Posted August 27, 2013 - 09:15 AM
i only plan on using the mower deck.  I will see if i can find the info on the swap.  What make the clutch so difficult?
#5 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,120 Thanks
  • 10,188 posts
Posted August 27, 2013 - 09:23 AM
The cylinders in my machines don't move either and it's never caused a problem.
The wife? She'll always find something to be mad about. It might as well be something good for you.
#6 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted August 27, 2013 - 11:03 AM
I take it your wife don't like bad engines.You always find this stuff out after you are married.
#7 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 2,012 Thanks
  • 1,093 posts
Posted August 27, 2013 - 04:25 PM
My other half hates it when i drag old stuff home, too. Although she usually comes around when she realizes how much better and cheaper it is than the new junk!
#8 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted August 28, 2013 - 01:30 AM
At two mowers you should be safe. I have stashed a few here and there - now if I only could remember where I put that one with the broken axle. I think it is next to the Cub with the bad tranny.
  • Trav1s said thank you
