Mtd 990 Weight
3 replies to this topic
#1 DH1 ONLINE
DH1
    Electric Tractors
  • 5,380 Thanks
  • 5,611 posts
Posted August 26, 2013 - 08:43 PM
How much does a MTD 990 without any attachments weigh?
  • 14,866 Thanks
  • 15,512 posts
Posted August 26, 2013 - 08:49 PM
Doug, Around 850lbs without a deck.
  • DH1 said thank you
#3 Canawler OFFLINE
Canawler
  • 1,950 Thanks
  • 1,806 posts
Posted August 27, 2013 - 08:19 AM
Good question.
I have sales brochures from three different versions of the 990 and all show different weights.
The '71 MTD brochure lists the weight as 875 lbs.
The '75 Columbia brochure says it's 1035 lbs.
A late '70s White brochure also says 1035 lbs.
I'm wondering if the 160 lb. difference is the deck?  Maybe the Columbia and the White have a deck as standard equipment?  I can't imagine what would be different between the tractors that would make that much difference.  I know the 3-point hitch was standard on some models and not others but that's no where near that much weight.  Same with the grills being different castings on all three.
  • DH1 and Sawdust have said thanks
#4 HALFSCALE OFFLINE
HALFSCALE
  • 508 Thanks
  • 534 posts
Posted August 27, 2013 - 04:48 PM
The decks on the Whites and Columbias are an option just like the standard MTD, the grille on a MTD is about 11 pounds , the White and Columbia are a little heavier but the White uses a fiberglass hood. So I'm with you Jim, I don't see where they get that big of a weight difference.
