The Infamous 4 Seat Bolens
bolens wisconsin
43 replies to this topic
#16 CubHorse80 OFFLINE
CubHorse80
  • 162 Thanks
  • 318 posts
Posted August 26, 2013 - 03:15 PM
What is the model number on the engine? It looks like it would be good for picking field tomatoes.
4309122
good idea on the tomatoes! :dancingbanana:
#17 CubHorse80 OFFLINE
CubHorse80
  • 162 Thanks
  • 318 posts
Posted August 26, 2013 - 03:16 PM
I mean the model is S-8d. other is serial
#18 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 19090 Thanks
  • 11897 posts
Posted August 26, 2013 - 03:18 PM
If original, the S-8D is an 8 hp engine.
#19 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 18307 Thanks
  • 7715 posts
Posted August 26, 2013 - 03:21 PM
Im only 18! hahahahaha :bounce:
Better get busy buster!!   :tapping_fingers:  :bigrofl:  :bigrofl:  :bigrofl:
  • CubHorse80 said thank you
#20 CRFarnsworth OFFLINE
CRFarnsworth
  • 5683 Thanks
  • 2422 posts
Posted August 26, 2013 - 04:26 PM
Then you have time to install the "Mother-in-Law" seat on the rear of the tractor. :D
Nice parade outfit you've bought.   Rick
  • WNYTractorTinkerer and CubHorse80 have said thanks
#21 CubHorse80 OFFLINE
CubHorse80
  • 162 Thanks
  • 318 posts
Posted August 26, 2013 - 05:35 PM
SO IS THIS AN 850????
#22 Newpaws493 OFFLINE
Newpaws493
  • 1390 Thanks
  • 1818 posts
Posted August 26, 2013 - 06:26 PM
i do not have that. so is there a belt in the middle then shafts on front and back? how much are they used? and how are they enguaged?
I don't see the PTO in your pics, as it would/ should be @ center, below nornal front axle. (right about where there now seems to be a central support square tube extension) Ido see the engagement lever., it's the bent one with small  thin bracket. all the way left is off, right is on. Wouldn't imagine it's connecting to any thing now. Good luck, it's a very interesting piece as it's now configured.
#23 CubHorse80 OFFLINE
CubHorse80
  • 162 Thanks
  • 318 posts
Posted August 26, 2013 - 06:36 PM
so is that engaugement lever for the transmission or the pto? and what goes in the hole on the dash behind it? Do you know if its an 850?
#24 EricFromPa ONLINE
EricFromPa
    Fixer of Broken junk
  • 6873 Thanks
  • 4608 posts
Posted August 26, 2013 - 06:50 PM
Looks like an 850 to me.It's missing the Hi/Lo leaver just above the Pto leaver.
Wisconsin S8D 8.25hp
There's a Lift handle on Ebay.Seems a Little pricey but looks to be complete.
http://www.ebay.com/...=item5648709296
Edited by EricFromPa, August 26, 2013 - 06:51 PM.
#25 Traill95 ONLINE
Traill95
    Traill95
  • 2051 Thanks
  • 1082 posts
Posted August 26, 2013 - 07:13 PM
That looks like something Rick and I would make. :D
Edited by Traill95, August 26, 2013 - 07:14 PM.
#26 CubHorse80 OFFLINE
CubHorse80
  • 162 Thanks
  • 318 posts
Posted August 26, 2013 - 07:35 PM
So its hi lo tranny? whats that linkage look like?? how can i check?
#27 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted August 26, 2013 - 07:45 PM
I would say it was an 850
Looks to be hacked up a bit and missing parts.....
Are those chrome strips easily removable on the hood?
Going to be hard putting decals on with all that in the way
#28 CubHorse80 OFFLINE
CubHorse80
  • 162 Thanks
  • 318 posts
Posted August 26, 2013 - 07:57 PM
What do you see missing right off the bat?
#29 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted August 26, 2013 - 08:06 PM
OEM Steering wheel, OEM Seat, Headlights, Hi/Low range speed selector, PTO assembly, Driveshaft Nut, OEM Steering Draglink
#30 CubHorse80 OFFLINE
CubHorse80
  • 162 Thanks
  • 318 posts
Posted August 26, 2013 - 08:19 PM
I know i need steering wheel, seat, headlights, hilo range selector, pto assembly, and lift assembly.
I have the origional draglink.
what is the driveshaft nut?
Also tagged with one or more of these keywords: bolens, wisconsin
