Need Help Finding A Mtd Deck Spindle
4 replies to this topic
#1 farmerall OFFLINE
farmerall
  • 2,207 Thanks
  • 1,475 posts
Posted August 25, 2013 - 05:00 PM
I am trying to find a spindle for my neighbors lawn tractor. It is a Hechinger model 138-658-372. I have searched and found the parts list for the tractor itself but nothing was in the parts list about the deck. The deck is a 38in two blade mower deck. Can anyone tell me where to look  for the parts list or a part number for the spindle? I came across this one on ebay and it looks the same but I don't want to tell him to buy it unless it will work.
http://www.ebay.com/...6c#ht_863wt_932
#2 Gtractor ONLINE
Gtractor
    the homeless tractor hoarder
  • 9,642 Thanks
  • 5,045 posts
Posted August 25, 2013 - 05:19 PM
Take the old spindle assy. to your local auto parts store.  They can look it up in their "Prime Line" parts book and compare it with the picture.
The Prime Line part # for the spindle's picture you posted from Ebay is
7-04266
  • CRFarnsworth and farmerall have said thanks
#3 New.Canadian.DB.Owner OFFLINE
  • 2,347 Thanks
  • 1,502 posts
Posted August 25, 2013 - 06:10 PM
That style of spindle has replaceable bearings.  They are a standard size, not some weird, one-of, NLA type item.
#4 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted August 26, 2013 - 05:24 AM
Here's two deck manuals:
View
View
#5 EricFromPa ONLINE
EricFromPa
  • 3,975 Thanks
  • 3,247 posts
Posted August 26, 2013 - 10:31 PM
Yep they sure are.I rebuilt 2 decks last month with those exact same spindles.If they just need bearings go to TSC Tractor Supply Or your local Napa.Bearings are around $10 for a set.
They are easy to change to.I did mine with a chunk of 1" pipe,2 big rocks,2 1/2" wrenches and a 3lb sledge hammer.
I didn't have Press with me so I had to make due with what I had at the time.It was still Very easy.
Simple Crude pic explaining how to knock the bearings loose.(Hey it Works) Make sure the NUT is Flush with the shaft before you go tapping on it or you WILL damage the threads.And don't beat it just Tap it.They're not on there that snug.
They're VERY VERY easy if you have a Press.I did the 2nd set of spindles in my neighbors Arbor press.We have a big press down at the farm but I didn't feel like running the whole way down there just to press a set of bearings out.
