Difference Between The Kohler K90 And K91?
4 replies to this topic
#1 Bolens 1000 ONLINE
  • 14,612 Thanks
  • 17,952 posts
Posted August 24, 2013 - 07:01 PM
This may have been brought up before but whats the difference between the K90 and K91 engines besides the magnetos and HP rating?
My main concern is would the Piston rings & piston interchange between the two?
I'm guessing they probably wont interchange as the K91 most likely has a larger bore to get the extra HP.
#2 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 12,241 Thanks
  • 9,178 posts
Posted August 24, 2013 - 07:14 PM
Have you checked the service manual?
#3 Bolens 1000 ONLINE
  • 14,612 Thanks
  • 17,952 posts
Posted August 24, 2013 - 07:24 PM
The one parts list only gives single ring part numbers and the other gives the part number as a set so I cant verify part numbers that way....
#4 drbish ONLINE
drbish
    Collecter
  • 1,496 Thanks
  • 1,316 posts
Posted August 24, 2013 - 08:37 PM
Here is some info i have
Attached File  kohler partnu.PDF   1.35MB   128 downloads
  • Bolens 1000 said thank you
#5 AVB OFFLINE
AVB
  • 138 Thanks
  • 135 posts
Posted August 24, 2013 - 10:38 PM
It looks like the K90 power is rated at 3600rpm vs the K91 at 4000. Everything I see shows the bore, stroke and replacement piston being the same.
I don't know if there is an old style vs. new style difference like with the forged pistons for other models. Where you have to use the new style rod with the Mahle piston.
Edited by AVB, August 24, 2013 - 11:01 PM.
