Voltage Regulator
voltage regulator suburban
4 replies to this topic
#1 dutchman54 OFFLINE
dutchman54
  • 4 Thanks
  • 6 posts
Posted August 24, 2013 - 04:13 PM
Thank you for the help with my reverse rotation starter earlier this month.
The voltage regulator on my 1966, model 917.99421 Suburban is rusted out and no longer working.  Is there a generic regulator or original source to replace these units?
Thanks for your help, Dutch
  • JRJ said thank you
#2 HDWildBill OFFLINE
  • 8,984 Thanks
Posted August 24, 2013 - 04:30 PM
Try our site sponsors they may be able to help.  Here is the part number for the regulator, 606A190
  • dutchman54 said thank you
#3 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted August 24, 2013 - 05:19 PM
I think this one will work:  http://www.psep.biz/..._regulators.htm
GRAVELY Starter generators
JACOBSEN Starter generators
TECUMSEH Starter generators
  Picture OEM # Part # Your Price Buy It!   435-040.jpg BRIGGS & STRATTON 295924
CUB CADET IH-545130-R93
CUB CADET 545130-R93
DELCO 1118981
DELCO 1118988
DELCO 1233688
DELCO D655
GRAVELY 007275
JACOBSEN 107927
JOHN DEERE AM30078
MASSEY FERGUSON 1825-48-M91, 1825-48-M92, 1900-343-M91, 511-472-M1
PRESTOLITE 8-297, 8-788, GRX-297
TECUMSEH 32089
435-040 / 1297 / GDR6005 MES81-1907
REGULATOR
$15.88
& ONLY 7.95 FLAT RATE SHIPPING AND HANDLING PER WHOLE ORDER
MES81_1907 IS A FIREWALL MOUNTED REGULATOR
  • Petenpole, HDWildBill and MountainMichael have said thanks
#4 dutchman54 OFFLINE
dutchman54
  • 4 Thanks
  • 6 posts
Posted August 25, 2013 - 05:50 PM
Wild Bill and Olcowhand, you guys are awesome, thank you.
#5 MountainMichael OFFLINE
MountainMichael
  • 167 Thanks
  • 81 posts
Posted August 30, 2014 - 09:30 PM
DELCO 1118981
DELCO 1118988
DELCO 1233688
DELCO D655
GRAVELY 007275
JACOBSEN 107927
JOHN DEERE AM30078
TECUMSEH 32089
REGULATOR
$15.88
Has anyone used this regulator to replace the long since no longer available Sears 606A190 ?  If yes, how did it work out for you?  Any odd modifications necessary?
If you checked charging voltage, what was it running?  Were you able to adjust it?
Thanks,
mm
Edited by MountainMichael, August 30, 2014 - 09:38 PM.
Also tagged with one or more of these keywords: voltage regulator, suburban
