Jd 400 With.....loader?
This topic has been archived. This means that you cannot reply to this topic.
7 replies to this topic
#1 TAHOE ONLINE
TAHOE
  • 7,814 Thanks
  • 5,612 posts
Posted August 23, 2013 - 12:20 PM
Not sure if I would call that a loader or FEL.
Am I looking right, are those arms like 1" tube and the bracing just angle iron?
I would be afraid to lift anything with that, the hydro cyls would twist it in half.
http://www.ebay.com/...7wt_917</p> <p>
$T2eC16F,!ykE9s7tw!lgBR-,VKK,Sg~~60_1.JP
#2 OldBuzzard ONLINE
OldBuzzard
  • 6,984 Thanks
  • 4,783 posts
Posted August 23, 2013 - 03:10 PM
Your link didn't work, but I did find it:
http://www.ebay.com/...=item19de1d2958
Listing is for the loader ONLY.
The cylinders look like they are stout enough to lift an elephant !!!!
However, the rest of the loader might not be able to handle said elephant's t**d :rolling:
Edited by OldBuzzard, August 23, 2013 - 03:10 PM.
#3 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted August 23, 2013 - 03:13 PM
I wouldn't trust that with anything but mulch :D
#4 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted August 23, 2013 - 03:27 PM
:wallbanging:
#5 JDBrian OFFLINE
  • 9,609 Thanks
  • 14,144 posts
Posted August 23, 2013 - 06:10 PM
If you look at all the pictures in the Ad it's a pretty strange setup. The angle that the lift cylinder is working at is going to limit the lift capability and the loader arm pivots look like they are just bolted to the angle iron which is not very strong to say the least.
#6 olcowhand ONLINE
  • 40,355 Thanks
  • 31,174 posts
Posted August 23, 2013 - 08:21 PM
Yep, that lift cylinder geometry won't allow much of a load to be lifted.  Good thing it's ran off the hydro charge pump, as with a normal hydraulic pump's higher pressure, that lift cylinder geometry would pull the loader in half!
#7 KC9KAS OFFLINE
KC9KAS
  • 5,326 Thanks
  • 4,672 posts
Posted August 23, 2013 - 08:41 PM
From the looks of things, you could dump a bucket load right on top of your hood by tilting back all the way.
#8 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted August 23, 2013 - 10:43 PM
Just because you can... doesn't mean you should.
