Wanted
Mtd 990 Rear Lift
9 replies to this topic
#1 Jlaws OFFLINE
Jlaws
  • 554 Thanks
  • 368 posts
Posted August 23, 2013 - 11:26 AM
I'm in the process of restoring a MTD 990 and need the rear Cat 0 lift arms , they're called draft bars on parts assy . Condition not important , If incomplete that's OK too . I have the ability to fabricate missing parts .
Email me a price shipped to 41051 .
Thanks , Jess
  • JRJ said thank you
#2 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted August 23, 2013 - 11:41 AM
I believe the 990 draft bars are 1-1/2" plain flat stock, 3/8" thick? maybe thicker. with 5/8: holes on each end, all you need is the length, a metal saw, and a drill, or drill press
#3 Jlaws OFFLINE
Jlaws
  • 554 Thanks
  • 368 posts
Posted August 23, 2013 - 12:05 PM
If someone could give me dimensions I could make me a set .
Between Tractor Supply and my welder , making them wouldn't be a problem .
  • OkieGt said thank you
#4 Arti OFFLINE
Arti
  • 1,363 Thanks
  • 989 posts
Posted August 23, 2013 - 12:33 PM
The last 3 point that I shipped cost me $30. and change, So it depends on how much of it that you need.
I don't have the bracket for the top link or the top link. Also this has a fairly heavy bar across the back to make it usable for a drawbar.
I was going to offer the complete tractor for $300. with the deck however it seems that i'm more than likely going to part it out. This is a good running tractor. It is missing the wheels for the deck other than that it could be easily used to mow with. If you want or need some other parts it would be simpler to ship them all at once.
  • JRJ and OkieGt have said thanks
#5 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
I dont rhink you need a welder, do you have the parts manual, if not one of the MTD guys can give you the measurements and pictures of the parts
#6 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted August 23, 2013 - 12:35 PM
wow sweet deal!!!
#7 Jlaws OFFLINE
Jlaws
  • 554 Thanks
  • 368 posts
Posted August 24, 2013 - 08:23 PM
It is a good deal but , he's 3 states over . All I need is the two lift arms , The rest of the tractors isn't  in that bad of shape , even the plastic dash is in good shape .
I have the manual , but it doesn't give the lift arm dimensions .
It doesn't look like anyone is gonna give me any measurements .
Arti shoot me a email if you want to sell those lift arm .
Edited by Jlaws, August 24, 2013 - 08:24 PM.
#8 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted August 24, 2013 - 08:57 PM
I have mine on a shelve in the shop and if I can remember and have time tomorrow I will get you the dimensions.
  • Jlaws said thank you
#9 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,801 posts
Posted August 25, 2013 - 09:16 AM
I just looked around on my computer and apparently I never saved a copy but I remember someone actually did up a full set of drawings for the lift arms.  I don't have time to search right now but they were over at MTF, maybe even in the MTD stickies forum??  If you look around a bit over there you'll find they're exactly what you're looking for.  I remember they gave dimensions for the offset and may have even given the radius of the bends.
#10 Jlaws OFFLINE
Jlaws
  • 554 Thanks
  • 368 posts
Posted August 25, 2013 - 09:38 PM
Canawler , I found those drawings you were talking about on MTF for the MTD rear lift....Thanks
Texas Deere , thanks for the offer , but I think I'm set now ...
I'm going to look into making a set or possibly modifying a set made for another model GT .
Edited by Jlaws, August 25, 2013 - 09:41 PM.
