Ever Seen Something Like This?
39 replies to this topic
#31 KennyP ONLINE
  • 38,490 Thanks
  • 45,978 posts
Posted August 24, 2013 - 06:16 AM
It is in the narrow area between the cylinder and valve housing as near as I can tell. It's hard to even see in there to figure out exactly where it's coming from let alone to weld in there. JB weld wouldn't hold in that application IMO. The cylinder wall is scored a bit in the area opposite the exhaust valve and one of the score marks is probably a fine crack.
   I cleaned the engine up last year and ran it to find out where the oil was coming from. This picture was after running for about 5 hours.  I cleaned it up again and ran it for about 1/2 hour and you could see it was coming from that narrow passage between the valve and cylinder sections of the block. Pretty much impossible to get at.
I wonder if you could sleeve that block?
I still dont know what the balance gears are do you see them in my pics? I would scrap em if possible. I hear the are a cause of troubble
  • js5020 and hatedge have said thanks
#32 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted August 24, 2013 - 06:28 AM
Yes, it probably could be sleeved but the engine would also need a rebuild. I'm still looking for another engine and was just talking to someone with a K321 block but it looks like it's the wrong type.
  • KennyP and hatedge have said thanks
#33 js5020 OFFLINE
js5020
  • 684 Thanks
  • 787 posts
Posted August 24, 2013 - 07:18 AM
Some Kohlers have balance gears and some dont,,,, this 341 had em the 301 doesnt.
  • hatedge said thank you
#34 hatedge OFFLINE
hatedge
    Beer Guzzling Canuck
  • 292 Thanks
  • 577 posts
Posted August 24, 2013 - 02:23 PM
Well it seems I do have them balance gears in my 321. What exactly is the problem with those again?
#35 KennyP ONLINE
  • 38,490 Thanks
  • 45,978 posts
Posted August 24, 2013 - 02:25 PM
The bearings give out, letting them make a picture window into the block!
#36 hatedge OFFLINE
hatedge
  • 292 Thanks
  • 577 posts
Posted August 24, 2013 - 02:26 PM
I tried to get the connecting rod off the piston skirts today and what was left of the pston just collapsed in my hands when I tried to get the circlips off. Guess it was pretty weak in a few places.
#37 hatedge OFFLINE
hatedge
  • 292 Thanks
  • 577 posts
Posted August 24, 2013 - 02:30 PM
hum.... I dont think I really NEED a picture window in the block. I wouldnt want the crank to get a cold this winter then call in sick when the first storm hits.  :D
Is there anything I need to do when taking them out? or do I just take em off and thats it?
#38 olcowhand OFFLINE
  • 41,269 Thanks
  • 31,447 posts
Posted August 24, 2013 - 02:37 PM
Just take all gears & associated parts (shims & clips) out and you're done.
#39 KennyP ONLINE
  • 38,490 Thanks
  • 45,978 posts
Posted August 24, 2013 - 02:38 PM
Unless you want to buy new bearings for them and mike the shafts they run on, take them out.
Yeah, What Daniel said!
#40 hatedge OFFLINE
hatedge
  • 292 Thanks
  • 577 posts
Posted August 25, 2013 - 12:19 PM
Can someone tell me how to know if I need the old style or new style piston in my engine?
