Ac 416S Starter
3 replies to this topic
#1 Frank Dodson OFFLINE
Frank Dodson
  • 5 Thanks
  • 12 posts
Posted August 22, 2013 - 04:55 PM
My 416S starts most of the time however sometimes the starter seem to grind. I tap the starter and this takes care of the problem. Is the starter worn out? Thanks
#2 Cat385B OFFLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted August 22, 2013 - 10:43 PM
Most likely it needs to be dis-assembled and cleaned. It is 40 years old.
Wait...I'm 40! I better have that done.....
#3 Frank Dodson OFFLINE
Frank Dodson
  • 5 Thanks
  • 12 posts
Posted August 23, 2013 - 03:44 PM
Thanks for the help.
#4 olcowhand ONLINE
  • 40,371 Thanks
  • 31,177 posts
Posted August 23, 2013 - 07:58 PM
Could be the brushes are worn to the point they barely contact the pickups on the armature.  Tapping will get them to contact better to a point.  Gotta be careful tapping the cases on these starters, as the magnets are glued to the casing & you can bust them up.  In fact, already busted magnets could be your problem.
