Case 446 Deck Lift Cylinder Re-Purpose
2 replies to this topic
  • 10 Thanks
  • 21 posts
Posted August 21, 2013 - 08:01 AM
As the title states.
I am thinking of moving the deck lift cylinder from its original position to the snap fast bracket in order to lift a dozer blade and snowblower.
This would eliminate building and routing a lift linkage from the mid mount position.
The snowblower pto box, pto shaft and steering linkages all consume any straight line access to the snowblower and dozer blade for a lift linkage.
By relocating the deck lift cylinder I should be able to come from above all the previously mentioned obstacles.
It would require fabbing a mount for the cylinder and adding longer lines.
Your thoughts.... :help:
#2 twostep OFFLINE
  • 1,987 Thanks
  • 2,538 posts
Posted August 21, 2013 - 08:13 AM
Sounds like a good idea... after all that how the power blades work. Go for it and post up pictures.
#3 tractorgearhead OFFLINE
  • 1 Thanks
  • 6 posts
Posted September 12, 2013 - 03:54 AM
That a lot of work just to lift the blade or snow caster.
All you need is the mounting plate and the rod to make it stock.
I have seen the plains for both on another site it would not be much work
I'm new hear and I don't know if I can tell you witch site has the plains.
I have seen the parts you need on E-BAY for not to much cash.
