Straighten A Valve Head
14 replies to this topic
#1 TerryD OFFLINE
TerryD
  • 132 Thanks
  • 254 posts
Posted August 21, 2013 - 12:23 AM
Looks like my MF10 swallowed a choke plate scre and it hit the exhaust valve. I see a small dent in the top of it. Is there an easy way to straighten a valve that was knocked off of square? A new valve is $68.
Thanks!
  • JRJ said thank you
#2 KC9KAS ONLINE
KC9KAS
  • 5,161 Thanks
  • 4,545 posts
Posted August 21, 2013 - 04:05 AM
I think you would be time & money ahead to just replace the valve.
  • TerryD said thank you
#3 superaben OFFLINE
superaben
    Con Man
  • 7,665 Thanks
  • 5,677 posts
Posted August 21, 2013 - 06:17 AM
KC9KAS is right: you can technically heat up the valve and bend it, but you will loose the material strength of it.  $69 now is better than later having to pull the motor apart again.
Ben W.
#4 TerryD OFFLINE
TerryD
  • 132 Thanks
  • 254 posts
Posted August 21, 2013 - 06:44 AM
Okay. That's what I needed to know.
Thanks.
#5 LilysDad ONLINE
LilysDad
    Oh, shoot!!!
  • 11,797 Thanks
  • 8,921 posts
Posted August 21, 2013 - 06:53 AM
What make and model is that engine?
#6 TerryD OFFLINE
TerryD
  • 132 Thanks
  • 254 posts
Posted August 21, 2013 - 06:56 AM
Tecumseh HH100-115097c, 10hp.
Edited by TerryD, August 21, 2013 - 06:57 AM.
#7 Guest_gravely-power_*
  • Guests
Posted August 21, 2013 - 07:35 AM
Guys are right. Do NOT straighten a valve.
#8 Alc OFFLINE
  • 6,313 Thanks
  • 7,153 posts
Posted August 21, 2013 - 10:39 AM
I wonder how a little screw could have bent the exhaut valve ? I'm thinking this is a flat head engine right  ?  Has this happened to anyone before ?
#9 Guest_gravely-power_*
  • Guests
Posted August 21, 2013 - 11:47 AM
Yup, the screw got caught between the top of the valve and the head.
  • Alc and TerryD have said thanks
#10 Alc ONLINE
  • 6,313 Thanks
  • 7,153 posts
Posted August 21, 2013 - 12:48 PM
Oh man that stinks ! Must have just caught just the right spot on the valve  ?
#11 Guest_gravely-power_*
  • Guests
Posted August 21, 2013 - 01:28 PM
Yeah, I couldn't believe it.
#12 TerryD OFFLINE
TerryD
  • 132 Thanks
  • 254 posts
Posted August 21, 2013 - 02:34 PM
Okay, I've bit the bullet and ordered a new exhaust valve. Should be here in a couple day. On the upside, my carb is back from Carb Rescue!
#13 KC9KAS ONLINE
KC9KAS
  • 5,161 Thanks
  • 4,545 posts
Posted August 21, 2013 - 04:43 PM
You will be much happier with the results of a new valve!
Be sure to "lap" it when you install it.
#14 TerryD OFFLINE
TerryD
  • 132 Thanks
  • 254 posts
Posted August 21, 2013 - 04:48 PM
Definitely have to lap and adjust clearance. I am hoping for a world of difference when it runs.
#15 olcowhand OFFLINE
  • 38,033 Thanks
  • 30,448 posts
Posted August 21, 2013 - 04:50 PM
Had it happen to me once, and to 3 others I know.  Luckily none bent the valves though.
