Ford Lgt 165 Hydostatic Fluid!
8 replies to this topic
#1 Don Uhouse OFFLINE
Don Uhouse
  • 5 Thanks
  • 4 posts
Posted August 20, 2013 - 01:18 PM
I have been searching for the last couple of days to find the proper fluid to put in my LGT165 hydrostatic unit. I pulled up the service man. and it says
type F, I don't think It has ever been changed but it seems all the information I get is Different! It would be good If I could use Type F as it is a lot cheaper. but just want to find the right type to add to mine. Thanks Don Uhouse
  • JRJ said thank you
#2 TomLGT195 OFFLINE
TomLGT195
  • 3,162 Thanks
  • 2,447 posts
Posted August 20, 2013 - 01:53 PM
a good hydraulic fluid from NAPA (or tractor store) for tractors will work fine. i use it in both my Ford hydro's
#3 olcowhand ONLINE
  • 37,719 Thanks
  • 30,340 posts
Posted August 20, 2013 - 03:43 PM
Dexron III works just fine as well.  Dexron III matches Eaton specs to a T.  But I don't think you are supposed to run straight hydraulic fluid if you go that route.  It should be a hydraulic/transmission fluid.
#4 JDBrian OFFLINE
  • 9,595 Thanks
Posted August 20, 2013 - 05:10 PM
JD makes specific fluids for hydros. JD20D is a good fluid and only slightly more than ATF. If you want to go pricey Amsoil makes a synthetic fluid as well. About 10$/quart.
#5 KennyP ONLINE
  • 33,249 Thanks
  • 42,697 posts
Posted August 20, 2013 - 05:15 PM
Eaton does not recommend ATF or auto oils according to this service bulletin:
Attached File  Eaton_Hydraulic_Fluid_Recommendations.pdf   19.55KB   142 downloads
  • Arti said thank you
#6 olcowhand ONLINE
  • 37,719 Thanks
  • 30,340 posts
Posted August 20, 2013 - 06:06 PM
attachicon.gifEaton_Hydraulic_Fluid_Recommendations.pdf
I believe that is referring to hydraulic systems, not to hydrostatic systems.
Attached File  ATF.pdf   146.94KB   46 downloads
#7 KennyP ONLINE
  • 33,249 Thanks
  • 42,697 posts
Posted August 20, 2013 - 06:14 PM
I don't understand it all, but I took the ATF out of mine!
#8 TomLGT195 OFFLINE
TomLGT195
  • 3,162 Thanks
  • 2,447 posts
Posted August 20, 2013 - 06:40 PM
Sorry ,that's what I meant.
  • olcowhand said thank you
#9 olcowhand ONLINE
  • 37,719 Thanks
  • 30,340 posts
Posted August 20, 2013 - 07:15 PM
No apology warranted.  I figured that's what you meant, but I was just wanting to clarify for others.
  • TomLGT195 said thank you
