Case 446 3 Point
15 replies to this topic
#1 bigspoon OFFLINE
bigspoon
  • 137 Thanks
  • 99 posts
Posted August 20, 2013 - 12:10 PM
A few pics of my 3 point on my 446, still need to make hydraulic lines, but don't know if I will be putting a selector valve on yet or not.
Sent from my HTC VLE_U using Xparent Red Tapatalk 2
  • hamman, boyscout862 and twostep have said thanks
  • 14,814 Thanks
  • 15,501 posts
Posted August 20, 2013 - 02:49 PM
Very nice build !! :thumbs:
Not to over think this. I do have to ask if you feel that the 1/4" uprights are heavy enough for the kind of loads the pivot point will see?
#3 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted August 20, 2013 - 05:03 PM
I had the same thought. It looks well built but not as heavy as a JD or MF 3 point hitch. I've always thought they were overbuilt but I wonder how strong it needs to be.
#4 gopher OFFLINE
gopher
  • 764 Thanks
  • 758 posts
Posted August 20, 2013 - 08:23 PM
Good fab work . I've seen these plans and it calls for 1/4 plate. If it's not adequate for his needs by the looks of his work he'd have no trouble beefing it up .
#5 bigspoon OFFLINE
bigspoon
  • 137 Thanks
  • 99 posts
Posted August 20, 2013 - 08:31 PM
I cannot take credit for the fab work guys, but the person that built this 3 point is freaking awesome at what he does and I only hope I'm half as good. But for the plans I got them from the colt,case, Ingersoll forum. I figure build it from the plans than tweek if need be.
#6 Case-Closed OFFLINE
Case-Closed
  • 309 Thanks
  • 155 posts
Posted August 27, 2013 - 10:49 PM
Considering the tensile strengh of mild steel is 24,000 psi there should be no problem what so ever with this hitch design. In the end it's only as strong as the 4 bolts that connect it to the tractor and as I recall that is 2 bolts in shear and the other two under a tensile load.
Edited by Case-Closed, August 27, 2013 - 10:51 PM.
#7 bigspoon OFFLINE
bigspoon
  • 137 Thanks
  • 99 posts
Posted September 07, 2013 - 01:30 PM
Well got lines ran and tested the lift cylinder. Works pretty good, but I have to reroute the the top line rubs on the top lift bracket to much. I have a total of 17in of travel at the lower lift arms
  • Texas Deere and Horse, gopher and dropped82 have said thanks
#8 gopher OFFLINE
gopher
  • 764 Thanks
  • 758 posts
Posted September 07, 2013 - 04:07 PM
Looking good....
#9 shorty ONLINE
shorty
  • 5,496 Thanks
  • 5,267 posts
Posted September 07, 2013 - 07:14 PM
That looks real good. With 17" of travel that will lift nice. :thumbs:
  • bigspoon said thank you
#10 bigspoon OFFLINE
bigspoon
  • 137 Thanks
  • 99 posts
Posted September 22, 2013 - 01:17 AM
Tested out the Case fab 3 point at the the ball hollow GT talk 2 nd annual plow day, and couldnt be happier. Will have to fab up some chains or sway bar, but other than that she work very well.
#11 MH81 OFFLINE
Posted September 22, 2013 - 02:20 AM
Glad it all worked out well for you. Looks like the hole rig is working well.
#12 KennyP ONLINE
  • 38,420 Thanks
  • 45,955 posts
Posted September 22, 2013 - 03:00 AM
Plow days are fun, aren't they? Glad it worked well for you!
#13 HowardsMF155 OFFLINE
  • 2,861 Thanks
  • 2,987 posts
Posted September 22, 2013 - 06:36 AM
Looks like that worked out very well for you.
#14 freedhardwoods OFFLINE
freedhardwoods
  • 374 Thanks
  • 197 posts
Posted September 22, 2013 - 03:13 PM
It looks like it came from the factory. Good job.
#15 olcowhand OFFLINE
  • 41,220 Thanks
  • 31,437 posts
Posted September 22, 2013 - 03:48 PM
Bigspoon, you're who came to my plow day with Doug E right?
