Anyone Need A H-1 140 900$!
This topic has been archived. This means that you cannot reply to this topic.
5 replies to this topic
#1 TractorGuy1994 OFFLINE
  • 259 Thanks
  • 165 posts
Posted August 19, 2013 - 09:19 PM
Clean 140! for 900!
#2 johndeereelfman OFFLINE
  • 5,730 Thanks
  • 2,603 posts
Posted August 19, 2013 - 09:29 PM
The price to me is very high, especially for an H1. If you notice, there are no front or rear hydraulics, so basically the only thing you can do with the tractor is mow, or plow if you invest in the complete rear lift set up. The headlights were added by the seller, and not factory installed, one because of the red lead wire, and two because there are no rear lights, just lenses. The light switch isn't original either. My price for this tractor would be more in the range of $400.00, and that is being generous.
Tractor does look good, and I would guess it to be around a 1973-74 model year.
#3 Trav1s ONLINE
  • 3,405 Thanks
  • 4,430 posts
Posted August 19, 2013 - 09:47 PM
I too would have guessed a '73 or '74.  The later 4-wheel deck is a bonus.  I was thinking $750...
Edited by Trav1s, August 19, 2013 - 09:48 PM.
#4 twostep OFFLINE
  • 1,987 Thanks
  • 2,538 posts
Posted August 19, 2013 - 10:15 PM
I can't believe no one has said anything about the crawler in the background, now that's what I'm talking about!!
It's easy to throw out numbers based on pictures but as we all know pictures paint a pretty tractor. Engine has been rebuilt so how worn out is the steering, ie: how loose are all of the controls.
The add says "factory headlights" but as elfman pointed out the read positive lead isn't right... of course it looks like the lights aren't connected together and I see now ground lead either???
In the end... if your going to repaint an entire tractor, INCLUDE THE WHEELS!!!
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted August 20, 2013 - 09:12 AM
Wish it was closer as I like it.
#6 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted August 20, 2013 - 10:08 AM
You need to get up close to value a tractor IME. There are a lot of expensive bits that could be worn out and that would lower the price considerably. Paint is cheap!
