Hello Gentlemen , I'm Back
13 replies to this topic
#1 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted August 19, 2013 - 06:56 PM
Well we got moved and everything pretty much settled in. Mainly is my garage is back in order. although a foot or so smaller.
Now for a bit of in formation.
What are the dimensions of the lockout rod for the rockshaft on my JD314 with single hyd? I was told I need one to operate my snow blade. I would like to make my own and I'm guessing you adjust with rockshaft in up position
Thanks for any help
larryd
  • olcowhand, KennyP, sacsr and 4 others have said thanks
#2 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted August 19, 2013 - 07:07 PM
Welcome back Larry. It's good to hear that the move went OK.  The lockout rod is a 3/8" partly threaded rod with a clevis (yoke) on one end and a square plate on the other. The clevis fastens with a 3/8" pin to the same hole the lift rod goes into. You retract the cylinder and then the force of the hydraulic pressure pulls on the rod. The rod is really strong in tension so it won't bend or break. The other end of the rod has a piece of square plate that sits in the slot in the rear plate. I've never seen a factory part but it would be easy to make. Just use 3/8" threaded rod. I'd use grade 5 if you can get it. You could even use 2 nuts to secure the plate at the right spot and wouldn't need to weld anything. Then just cut off any extra threaded rod and you're done. I need to make one for my 317 for use with the 49 snowblower I have.
Heres the diagram from JDParts
  • larryd and JRJ have said thanks
#3 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted August 19, 2013 - 07:14 PM
Glad to hear the move went well.  I know that is always stressful!
Ben W.
#4 daytime dave ONLINE
  • 4,785 Thanks
  • 6,524 posts
Posted August 19, 2013 - 08:01 PM
Larry, very glad to hear you are all moved in.  I hope to see you back here like usual.
#5 MH81 OFFLINE
Posted August 19, 2013 - 08:04 PM
Hey Larry, WB.
Thanks Brian, good info, anyone have approx dimensions?
#6 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,458 Thanks
  • 3,365 posts
Posted August 19, 2013 - 09:21 PM
Good to see you back!
#7 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted August 19, 2013 - 09:42 PM
Hi larry and welcome back! :wave:
#8 oldedeeres OFFLINE
oldedeeres
  • 9,177 Thanks
  • 4,644 posts
Posted August 20, 2013 - 01:43 AM
Glad you're back, have missed your posts.
#9 KennyP ONLINE
  • 37,542 Thanks
  • 45,531 posts
Posted August 20, 2013 - 01:53 AM
Glad to see you back, Larry. Hope Brian's post helps you!
#10 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted August 20, 2013 - 05:43 AM
Thanks Brian. I found that part finally in JD parts. I just wasn't looking in the right place or name. But I was hoping for dimensions but you were a great help there, thanks.
Thanks to everyone for the welcome back.
larryd
  • Trav1s and JRJ have said thanks
#11 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted August 20, 2013 - 10:17 AM
Larry, if you use treaded rod you can just get a length of it and cut it to length. For the plate on the back I'd guess it would be 2" or so square. Something like at least 1/4 or 3/8" plate should be strong enough.
#12 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted August 20, 2013 - 03:27 PM
Glad you have settled in! untitled larryd house.png   Do you have a John Deere wing?
#13 UncleWillie OFFLINE
  • 15,539 Thanks
  • 8,711 posts
Posted August 20, 2013 - 08:18 PM
I hate moving. If I ever move again I hope I am rich where I can just buy new stuff and leave everything here.
#14 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted August 21, 2013 - 02:54 PM
Wart Wagon I agree 100%
larryd
  • JRJ said thank you
