1614 Replacement Tire Question
3 replies to this topic
#1 TimW OFFLINE
TimW
  • 414 Thanks
  • 271 posts
Posted August 19, 2013 - 10:55 AM
I may be thinking wrong, but is there a skinny 16 inch automotive tire with conventional tread that will go on the PK rims?  Will the bead and rim hold an auto type tire?  I have a few sets or rims and would like to get some cheapish tires on them to roll the projects around.  If so, would anyone have a good guess on the P Metric size that matches up fairly well to the factory PK size?
Thanks
Tim
#2 olcowhand ONLINE
  • 40,354 Thanks
  • 31,172 posts
Posted August 19, 2013 - 10:59 AM
A P215 equals 8 1/2" wide, so that should do it.  If they are true 16" rims, any auto tire should work fine.
  • TimW said thank you
#3 glgrumpy OFFLINE
  • 8,558 Thanks
  • 7,878 posts
Posted August 19, 2013 - 06:22 PM
No problem with car or truck tires. Even the wheels are same bolt pattern as a Chevy truck with six lugs. Or some old mag wheels with truck bolt pattern.
  • Alc and TimW have said thanks
#4 TimW OFFLINE
TimW
  • 414 Thanks
  • 271 posts
Posted August 19, 2013 - 08:38 PM
Great info, if the six lug Chevy pattern works, I am sitting on several sets of wheels, I never thought to try that.
Thanks again
