Need A Few Dimensions Off A Case Gt
8 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted August 16, 2013 - 10:20 PM
Ok, I have a odd dilemma. I want to use Case Gt foot rests like on the 70s Case Gts on a Springfield and need a few dimensions. I know you all will say just go measure the ones on my 222, which is my problem. The guy came through with the money and it left tonight, Dad took the money and loaded it up for him. Therefore I can't just pull them for an hour and check it out 100%. I did get my asking price though. So anyway, on to the dimensions I'm needing to get by.
Overall length
Overall width
The size of the rockshaft hole
The diagonal cut clearance to the frame
And I notice they do vary slightly among the models, and some have tall or short rockshaft brackets. So I would need to know year and model as well as the height of that bracket.
Anyway, thanks for the help guys.
#2 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted August 16, 2013 - 11:20 PM
Sorry but mine are both from the 80's, but if need be I could get what you want from them
  • wvbuzzmaster said thank you
#3 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted August 16, 2013 - 11:48 PM
The foot rests I am wanting are the diamond tread steel ones, not sure when they quit using them, so just said 1970s.
#4 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted August 17, 2013 - 12:46 AM
Looking on google I am wondering if those later model foot rests wouldn't just be the ticket based on my goals and the shapes. Would you mind getting a few pics and dimensions of those, I guess similar to my original request. I need to understand the rear mounting holes, overall height, relationship of the flat and the rockshaft mounting hole. And relationship to the brake/rockshaft clearance cut outs. Heck, a few random pictures with a tape measure on the different sides would probably get me enough info to make an informed decision. If you can get me the info I need that would be awesome, if not, no worries. Thanks
#5 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted August 17, 2013 - 10:32 AM
Giving my thread a bump for the day
#6 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted August 17, 2013 - 10:45 AM
Hope these help,010.JPG 011.JPG 012.JPG 013.JPG 014.JPG 015.JPG 016.JPG 017.JPG 018.JPG 019.JPG 020.JPG
#7 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted August 17, 2013 - 11:34 AM
John, that helps a whole heck of a lot. I can definitely see if they will do what I want. The big question is still the diameter of the shaft they slide on to. Think you could get that dimension for me?
Thanks.
Edited by wvbuzzmaster, August 17, 2013 - 11:35 AM.
#8 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted August 17, 2013 - 12:35 PM
Well, I did a Lot of measuring and, they could work, if I cut the right ones notch another 5 inches longer.... And cut the backs off of em.... So I might need to do a little more shopping.... Unless I can reconfigure the tractor around them a little.... Hmmmm lol.
#9 CRFarnsworth OFFLINE
CRFarnsworth
  • 4,675 Thanks
  • 2,146 posts
Posted August 17, 2013 - 03:47 PM
Hers some pictures of the ones off my "basket case".  Approximately 6-1/4 x 9 1/2.  One side is bent up to attach to frame the other side catches your heel.  The brackets underneath fit on a 3/4" shaft.  Hope this helps.  Rick
