D B Fans
2 replies to this topic
#1 willy OFFLINE
willy
  • 73 Thanks
  • 86 posts
Posted August 16, 2013 - 08:00 PM
   Well I was asked to day to work on a DB 917-5751 # 158 . It does not have the right motor in it but came with a model N , no carb or manifold  good compression & spark . Little oily but may be crank breather needs cleaning ,no slop in piston or valves . ? Gasket set for motor , carb  & manifold , air horn . other motor came with 1 pcs. small flo-jet you know where air cleaner is right next to the carb . Saw a air horn on E-Pay & gasket set but $$ . If you tell me to take it back fine , Owner knows it will take time & money . I am new to DB's but like to wrench , if it was a Wisconsin or later Briggs , things would be diff.( got a few spare parts )
                                  Thanks Willy
#2 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted August 16, 2013 - 08:36 PM
Willy, I have a used carburetor for that N and a used air horn, but no oil bath air cleaner.
Ben W.
#3 willy OFFLINE
willy
  • 73 Thanks
  • 86 posts
Posted August 17, 2013 - 11:14 AM
  Hi Ben    What would you be asking for these ?
     Willy
