Update To 1855 Messed Up Pto Pulleys
13 replies to this topic
#1 Pudycatz OFFLINE
Pudycatz
  • 41 Thanks
  • 67 posts
Posted August 15, 2013 - 06:40 PM
After the welding mess I found, I have the pulley off of the shaft. With funds preventing me from taking to a machinist I've been working on this mess myself. Thought I share pics of what I found and get thoughts of how to proceed. Thanksgear2.JPG gear3.JPG gear1.JPG gear4.JPG
#2 Luke OFFLINE
Luke
  • 183 Thanks
  • 399 posts
Posted August 15, 2013 - 07:10 PM
You need a new/good used clutch assembly. Get a piece of 1/4 key stock from any hardware store and cut to length, grind all the slobbered weld off the end of the crankshaft and bolt the new clutch on and hook the wire back up so you can electrically engage/disengage it with the switch on dash like it was originally from factory instead of that mickey mouse manual system someone rigged up.
  • Pudycatz said thank you
#3 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted August 15, 2013 - 07:18 PM
Other than an OE replacement clutch, there is no easy fix here.  You can't simply buy a pulley to slip on the crank, as the pulley sits out from the end of the crank to align to the jackshaft pulley.  This would require machining a crankshaft pulley adapter that would reach out far enough to get the pulleys aligned.  Either a machinist must be involved, or go the easier, and possibly just as cheap route finding a used replacement clutch.
#4 Pudycatz OFFLINE
Pudycatz
  • 41 Thanks
  • 67 posts
Posted August 15, 2013 - 07:29 PM
 Thanks Luke, I think the search may be like looking for a needle in a hay stack. I'm gonna keep on the look out. It's a great running machine.
#5 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted August 15, 2013 - 07:30 PM
Nothing on ebay at the moment, but I'll stay on the lookout for ya.
#6 HowardsMF155 OFFLINE
  • 3106 Thanks
  • 3090 posts
Posted August 15, 2013 - 08:28 PM
Check with our site sponsors also.  One may have a parts machine with the clutch still on it.
#7 Luke OFFLINE
Luke
  • 183 Thanks
  • 399 posts
Posted August 16, 2013 - 11:26 AM
Let me do some looking around the farm, I think I might have a good used clutch setup laying around if memory serves me right!? Lol Give me the weekend to rummage around and see if I can locate it......got stuff stashed everywhere! Unless u wanna buy the brand new one(in box)I have sitting on the shelf!? Luke
#8 Pudycatz OFFLINE
Pudycatz
  • 41 Thanks
  • 67 posts
Posted August 16, 2013 - 01:31 PM
Thanks, either one will do. lol
#9 Luke OFFLINE
Luke
  • 183 Thanks
  • 399 posts
Posted August 16, 2013 - 05:55 PM
Here's the clutch assembly. It wasn't buried as deep as I figured! Lol do you need the complete assembly with the field coil or just the clutch part with pulley? It seems to be in good shape but one thing I would recommend is take some jb weld and smooth it over the coil windings to protect from the clutch wearing into them in time as the old covering is flaking off of them. Bearing seems to turn freely but I can't guarantee anything as its used! Let me know what parts ya need/want. Luke
#10 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted August 16, 2013 - 06:48 PM
P-catz, if you can afford, I advise buying the complete clutch from Luke.  Your electromagnet is beginning to look rough.  Luke's looks great.  Luke, do you have the retaining bolt & washer?
#11 Pudycatz OFFLINE
Pudycatz
  • 41 Thanks
  • 67 posts
Posted August 16, 2013 - 07:35 PM
Luke, sent you a PM, also as Olcowhand asked do you have the retaining bolt and washer
Edited by Pudycatz, August 16, 2013 - 07:43 PM.
#12 Luke OFFLINE
Luke
  • 183 Thanks
  • 399 posts
Posted August 16, 2013 - 08:08 PM
No, it's just a fine threaded bolt and heavy flat washer......just get a heavy washer that is just a touch larger diameter than the crankshaft and fits the bolt tight. Nothing special. Luke
#13 Luke OFFLINE
Luke
  • 183 Thanks
  • 399 posts
I can get you a length on the bolt tomorrow if needed!? Luke
#14 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted August 16, 2013 - 08:21 PM
Yep, that'll do fine.  I would also add a lock washer between the bolt head & large flat washer.
