Ford Lgt 145 Open Side Steering Gear Broken!
8 replies to this topic
#1 jodycon OFFLINE
jodycon
  • 2 Thanks
  • 2 posts
Posted August 15, 2013 - 12:24 PM
Hi all,
New guy to the forums here. I have the LGT 145 with the open sides so it is the older model.  I do not have any pictures and do not have the tractor at home to get any pictures.(sorry) It is used at my mountain house about 2 1/2 hours away. My first problem is the steering shaft broke, we took it apart and welded it once used it maybe twice and it broke at the weld again. I have done some searching around and cannot find one. The part number I came up with is JAC502384. Second problem is the return spring for the gas pedal is missing. Don’t know if anyone would have a picture of this so I can just make a new one or if anyone has one available. Part number on the return spring is JAC352501. Any help would be appreciated.
Thank you in advance
Jody
  • tinbender7 and JRJ have said thanks
#2 boyscout862 ONLINE
  • 12,848 Thanks
  • 9,169 posts
Posted August 15, 2013 - 12:55 PM
Welcome to GTT. I just bought an LGT 145 open side like you have. It is a great tractor. Check our manuals section for any info you made need. Check with our sponsors for parts. They are listed on the Home page. Good Luck, Rick
The spring may be replaced with a similar size universal spring from your local hardware store.
Edited by boyscout862, August 15, 2013 - 12:57 PM.
#3 tinbender7 OFFLINE
tinbender7
  • 1,115 Thanks
  • 784 posts
Posted August 15, 2013 - 12:57 PM
Joe's parts one of our sponsers may have whatc you need.I just purshased the spring yo refed to from him and he has several Fords he i parting out.
  • IamSherwood and JRJ have said thanks
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted August 15, 2013 - 01:21 PM
Welcome to GTTalk. Those Fords are a nice tractor. You could check with our sponsors as said above.
#5 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted August 15, 2013 - 02:39 PM
Welcome to GTtalk  several of the member have similar Fords and may be a help to you once they see your post.
Dick
#6 poncho62 ONLINE
poncho62
  • 1,736 Thanks
  • 1,663 posts
Posted August 15, 2013 - 06:29 PM
welcome...Had the same problem when I bought my LGT100.....I welded the steering shaft and it was still holding when I found another steering box. This breakage is common on these boxes.
  • IamSherwood said thank you
#7 Rock farmer ONLINE
Rock farmer
  • 1,198 Thanks
  • 1,233 posts
Posted August 15, 2013 - 08:26 PM
If yours broke where poncho's pictures show, you may be able to get the part you need on Ebay. These Ross steering boxes were used on John Deere, Cub cadet, Snapper and others. Some people charge through the roof for parts but they are common. No need to pay too much!
Joe
#8 jodycon OFFLINE
jodycon
  • 2 Thanks
  • 2 posts
Posted August 15, 2013 - 09:29 PM
Thank you all for the fast response. Time to do some more digging.
#9 boyscout862 ONLINE
  • 12,848 Thanks
  • 9,169 posts
Posted August 16, 2013 - 07:29 AM
Someone was selling rebuild kits for those steering boxes on EPAY. Included bearings and seals but I don't know about the shaft. They were very expensive. You may be able to buy the entire assembly for it at a reasonable price. Good Luck, Rick
