Lets See Those Original Tractors
52 replies to this topic
#31 TAHOE OFFLINE
TAHOE
  • 7,978 Thanks
  • 5,676 posts
Posted August 19, 2013 - 09:35 AM
I forgot about the wheel horse I just got, deck rusted away, but rest is orginal.
'75 B-80
photobucket-60336-1370866022671_zpsb0fe1
  • johndeereelfman, MFDAC and OkieGt have said thanks
#32 york0060 OFFLINE
york0060
  • 310 Thanks
  • 146 posts
Posted August 19, 2013 - 01:13 PM
Here is a couple of pictures of my 1983 JD 318, all orginal except for the seat.
#33 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted August 19, 2013 - 03:41 PM
Never seen one of those.
These Allis built Homelites were built in the South Carolina plant that close in 1974 and this particular tractor is unlike ANYTHING Allis or Simplicity built there are similarities , but the whole tractor is a odd ball. I believe the T-16 in this configuration was built in 1973, because in 1974 Simplicity was making them  on a standard 3400/7000 series frame and engine, early Simplicity built Homelites had Vickers Hydros, later ones had Eaton that was the only difference. But this Allis built Homelite is different that the 400 series and the 3oo series in appearance/sheet metal and design The front end is more like older Simplicity, but it utilizes a front electric PTO like the Allis 416, the Homelite has the same fender pan as a Simplicity 3300/3400, but the front hood is inverted Simplicity hood and the dash resembles the 1960s sloped design. The attachments for the front hook up different than any tractor built by either company. That said I believe these rolled off the assembly line with 400 series in the latter half of 1972 and I seriously doubt they made a 1000 Allis built T-16s, since reliable sources put the number of 416s made at less than 2000, and these were only marketed to indepentdant hardware stores
  • IamSherwood said thank you
#34 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted August 19, 2013 - 07:57 PM
Lets see your nicest most original tractors (original tires, original paint that looks good, stuff like that).  Personally those are my favorite. Here are a few of mine.
wanna tell us what they are, at least the last two, thanks
#35 Bob IN OFFLINE
Bob IN
  • 1,477 Thanks
  • 676 posts
Posted August 19, 2013 - 08:14 PM
Sorry about that. The walk behind is a monkey wards with the original tires. ( I love the button tread). And the tractor is a early moto mower 6000 series I believe.
  • OkieGt said thank you
#36 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted August 21, 2013 - 09:04 AM
well first up is the 1967 cub 123 that i sold to a friend an he mows with it once a week.
next we have my 1963 cub model 70. i built the fender in my welding class for a side project.
next up is Texas Deere and Horse's monty squire next to my 70
Edited by backwoods, August 21, 2013 - 09:04 AM.
  • johndeereelfman, jimbobbillyray, OkieGt and 1 other said thanks
#37 GTKen OFFLINE
GTKen
  • 11 Thanks
  • 3 posts
Posted August 22, 2013 - 09:11 AM
kens 149.jpg   First attempt at loading a picture. Hope it works. Here's my '74 149, all original except one front tire and the battery. Run regularly.  This is in the best condition of my originals. Most are pretty rough.
  • johndeereelfman and OkieGt have said thanks
#38 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted August 22, 2013 - 10:36 AM
I picked up this several weeks ago.All original 1975 Power King.
#39 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted August 22, 2013 - 10:39 AM
neat after market coil and custom engine tin
  • Kster526 said thank you
#40 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted August 22, 2013 - 10:59 AM
That is a factory solid state ignition coil and factory tin.
  • rustyoldjunk and Kster526 have said thanks
#41 Talntedmrgreen OFFLINE
  • 3,273 Thanks
  • 2,306 posts
Posted August 22, 2013 - 11:07 AM
Here are a few nice originals in the shop.  The Homie and Squire need baths, but should wash up nicely, and each came with nice tight original decks.  I'm impressed with the Squire's seat and that it still wears all 4 OEM Riverside tires.
The Serf I was able to find a nice, original seat for, and the hubcaps and lift kit came NOS.  The Wonderboy has lived an easy life...almost thinking the new caps lack the petina the rest of the tractor bears, however.  The reel was from a Lawn Trac, painted to go with it's Simplicity cousin...you can see some of the Wards bronze peeking through.
This is one of the latest models in the fleet, but one of the nicest finishes I've come across. (and probably my favorite)  The diesel and battery can really eat up the RH side of these machines if not cared for.  This one sat for a long time, at some point, with a bad battery, but is otherwise a peach.
  • johndeereelfman, js5020 and Kster526 have said thanks
#42 js5020 OFFLINE
js5020
  • 684 Thanks
  • 787 posts
Posted August 22, 2013 - 01:29 PM
Weeeellll this might be a bit big but it was my only GT at one time.  I bought it new in 1985, is all original except for the seat, front tires, and the busted flasher light on the back,,
[/URL]">http://IMG_3175_zpsdbaff954.jpg
[/URL]">http://IMG_3174_zps89b61168.jpg
It has 1056 hrs on it, this meter reads hours at rated engine rpms, not like the new ones that read off the key.
  • johndeereelfman, Talntedmrgreen and Kster526 have said thanks
#43 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted February 05, 2017 - 09:44 PM
Here's my 300 before I tore it down to rebuild itfc053adac1a35904aea4ab6664943107.jpg
Sent from my SM-S820L using Tapatalk
  • jimbobbillyray and Kster526 have said thanks
#44 Kster526 OFFLINE
Kster526
  • 845 Thanks
  • 560 posts
Posted February 06, 2017 - 07:09 AM
FullSizeRender.jpg 1965 JD 110 as it looked the day I brought it home. The seat is the only thing that has changed as it is now on the 74 112 after painting the seat back. I added an original pan seat. It still cuts grass now and then just to keep her active
Edited by Kster526, February 06, 2017 - 07:09 AM.
  • backwoods said thank you
#45 Talntedmrgreen OFFLINE
  • 3,273 Thanks
  • 2,306 posts
Posted February 07, 2017 - 09:01 AM
I've added (and let go of) a few nice originals in the past couple years
Edited by Talntedmrgreen, February 07, 2017 - 09:01 AM.
  • sacsr, MGP59DB and Mark 149 J. have said thanks
