Dozer Blade Mount
8 replies to this topic
#1 Firemang OFFLINE
Firemang
  • 187 Thanks
  • 197 posts
Posted August 14, 2013 - 07:33 PM
Can anyone who has an open side LGT with a blade send me some pics of how it's mounted?  I found a JD 43" blade in good shape at a garage sale for next to nothing and I want to try to build some new mounts for it and get it on my 145.  Maybe even put some electric over hydraulic cylinders on it so I can lift/lower and tilt it.  Thanks
New pics coming soon.  Got the 145 all torn down, all the small parts sandblasted.  Still need to send the tin and wheels out to a commercial blaster but almost all ready for paint!
#2 poncho62 ONLINE
poncho62
  • 2,232 Thanks
  • 1,830 posts
Posted August 14, 2013 - 07:45 PM
Mine uses the holes in the front to mount the blade with 2 pins......this is the only pic I can find right now
#3 Rock farmer OFFLINE
Rock farmer
  • 1,315 Thanks
  • 1,281 posts
Posted August 14, 2013 - 08:15 PM
The usual Ford LGT mount is under the frame, just in front of the rear end. It's not a good design because the plow only lifts a couple of inches. It's under the front axel. Better just to start from scratch! Poncho's is unusual.
Joe
#4 poncho62 ONLINE
poncho62
  • 2,232 Thanks
  • 1,830 posts
Posted August 15, 2013 - 05:47 AM
Joe
I think it is factory though....The blade has the Ford stickers on it...I should look for a serial number I guess
#5 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted August 15, 2013 - 11:02 AM
Poncho , how does the plow lift ? Is it connected to the deck lift lever above the pivot point or below , like the rear lift does ?
#6 poncho62 ONLINE
poncho62
  • 2,232 Thanks
  • 1,830 posts
Posted August 15, 2013 - 06:32 PM
It attaches above the pivot on the handle...no hydraulic lift on my tractors.
#7 Rock farmer OFFLINE
Rock farmer
  • 1,315 Thanks
  • 1,281 posts
Posted August 15, 2013 - 08:18 PM
You've got to get a picture of the other side of your tractor! That seems like a sixties blade made to fit. Maybe something the dealer did?
Maybe a ford blade with a different mount? I don't know. But it looks like a good set up!
Joe
#8 poncho62 ONLINE
poncho62
  • 2,232 Thanks
  • 1,830 posts
Posted August 16, 2013 - 05:28 AM
Heres the best I could find...its just a  "U" bolt attached to the lever, which connects to a flat bar to the blade mount....Unlike the under frame ones, it lifts nice and high
#9 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted August 16, 2013 - 08:00 PM
That's a nice tractor, much nicer than mine.
