B112 Quit Moving
6 replies to this topic
#1 rowder OFFLINE
rowder
  • 6 Thanks
  • 15 posts
Posted August 13, 2013 - 11:47 PM
hi guys I was mowing with my b112  and I made a funny noise then quit moving the mid pto transmission nothing runs exept the moter has anyone had this happen before  , thanks guys
#2 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted August 14, 2013 - 05:58 AM
My first thought would be the drive shaft couplers.  They are a round fiber(?) disk that connects the engine to the drive shaft and the drive shaft to the BGB.
  • boyscout862 and rowder have said thanks
#3 MH81 OFFLINE
  • 29,979 Thanks
Posted August 14, 2013 - 07:00 AM
:ditto:
That's exactly what popped into my head as I read what happened.
#4 rowder OFFLINE
rowder
  • 6 Thanks
  • 15 posts
Posted August 14, 2013 - 10:39 AM
boy that sounds better than the gear box going out , are the fiber couplers available, thanks guys
#5 MH81 OFFLINE
  • 29,979 Thanks
Posted August 14, 2013 - 11:17 AM
Dont get me wrong, it could still be the BGB.  there is a key in there that may be sheared too.
As for the Drive coupler... if the engine is turning and the shaft isnt (or isnt attached) you found your problem.
Contact the Site Supporters for the stuff.  If they cant help you, there are other options.
  • rowder said thank you
#6 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted August 14, 2013 - 11:33 AM
... are the fiber couplers available ...
I read somewhere (not sure where), that you can make them out of fiberglass.  Once you know how big & thick they are, find a similar size hole saw and a useless (but still structurally good) fiberglass panel.
  • MH81 and rowder have said thanks
#7 MH81 OFFLINE
  • 29,979 Thanks
Posted August 14, 2013 - 11:37 AM
One more thing popped in my head.  Flip up the seat pan and check to make sure the side to side shaft in the BGB isn't slid one way or another.  The gear is more or less held in place on the keyway by the pullies on the outside of the box keeping the shaft in place.
